Clutch Adjustment issue 67 L-79 - NCRS Discussion Boards
  • Lawrence S.
    • April 1, 1993
    • 807
    Re: Clutch Adjustment issue 67 L-79
    Originally posted by Bill Irwin (48515)
    Glad you got it working Larry. That 1'-1/2'' is NOT really that critical. It is the distance the petal moves downward till you feel the resistance. Use you hand to push down. 1/2, 3/4 or more, you're OK. Bill
    I expect the real measurement is the 3/8 - 7/16 of an inch that you adjust for on the pedal rod?
    Lawrence
    • Rich G.
      • August 31, 2002
      • 1406
      Been there. When I bought my 66 L79, the PO had done the same thing. He "fixed" it by making his own longer clutch rod. It worked, but I didn't want a home made clutch rod, so I got the right one. Then the clutch didn't work. So we changed the TO bearing. All good.
      Rich
        Originally posted by Lawrence Shaw (22476)
        The LUK clutch kit (part number 04-21) is in the car now and everything seems to be fine. I adjusted the clutch per the Chasis Service manual, but I could not get 1.25" of free pedal travel from the rubber bumper.
        Larry -
        The pedal free play measurement is made at the pedal itself, not between the pedal arm and the rubber bumper; shown in UPC 7, sheet A3 in the Assembly Manual.
        • Lawrence S.
          • April 1, 1993
          • 807
          #19
          Larry -
          John thanks for the info.
