67 trailing arms - NCRS Discussion Boards
67 trailing arms
  • Lawrence S.
    • April 1, 1993
    • 804
    67 trailing arms
    Is there a way to tell small block from big block trailing arms on a 67, or are they the same?
  • Rich P.
    • January 12, 2009
    • 1361
    Re: 67 trailing arms
    Original from the factory 67 BB rear trailing arms had 2 holes on either side of the upper spring bolt hole to mount the sway bar bracket.
    Rich
    • Tom D.
      • September 30, 1981
      • 2139
      Search archives for comments about those holes. Should be more there.
      Tom
      https://MichiganNCRS.org
      Michigan Chapter
      Tom Dingman
        As received at St. Louis, there was only one pair of trailing arm assemblies; if the car was a big-block, the two holes for the stabilizer bar mount bolts were added in an off-line bench drill fixture adjacent to the Frame Line.
