Diff to x-member mounting washer - NCRS Discussion Boards
  • Steve L.
    • June 30, 2001
    • 763
    The AIM shows lock washers under the 4 bolts that hold the Diff to x-member. My unmolested 73 has flat washer with no lock washer.
    These flat washers look distorted into a cup shape. Did they change to flats because the x-member holes are too big and lock washers won't work?
    Which is correct?
    Steve L
    73 coupe since new
    Capital Corvette Club
    Ottawa, Canada
  • Timothy B.
    • April 30, 1983
    • 5178
    Re: Diff to x-member mounting washer
    Steve,
    The flat washers are correct, there is no need for the lock washer. I would put a drop of loctite on each but not the red stuff. You may want to remove these sometime in the future.
    Make sure the four attaching bolts are grade eight..
    • Michael W.
      • March 31, 1997
      • 4290
      Why? Were the original bolts grade 8?
      • Gary R.
        • March 31, 1989
        • 1796
        I use gr 8 with lock washers. They hold tight and no one is going to see them anyway.
        • Steve L.
          • June 30, 2001
          • 763
          Flats with blue loktite it is.
          Dr R and Paragon sell these sets with splits. They must be following the AIM.
          I suspect that the x-member holes are too big for splits to work properly. I'm gonna check this out.
          Steve L
          73 coupe since new
          Ottawa, Canada
            • January 31, 1988
            • 43198
            Mike-----
            The original bolts were GM-300M material grade (SAE grade 8).
            • Graeme B.
              • October 23, 2007
              • 213
              Steve, I wondered the same. My mid '69 has flat washers too.
