What do you guys think about this carb on my 1966 300hp engine. It appears to be the correct carb a Holley 3367 stamp# 3884505-DA but the date code is 042(sorry i had to resize the pic and I don't think you can make out the date code) which would be April 2, 1970. Could this be correct, in Corvette by the #'s this is the right application but the date code should be 642. The author says these carbs were hand stamped and errors could occur, but my thinking is it is a replacement. My feeling is that they must have made these for other cars in the 70's. is this true? If it is a replacement how much do they ding you for the wrong date code?Let me know what you guys think. I also enclosed a copy of the intake manifold # 3872783 with casting date E116 (May 11, 1966). This appears to be correct. Sorry for some reason I can't download the pics. Thanks for any help in advance. Bob.
1966 Carburetor Question
Re: 1966 Carburetor Question
Robert ,
It is most likley a "service replacement" carb from 1970 . The 3 digit date code give that away. They still make the 3367 carb today, or at least they did a few years ago, but now, it is an After Market Carb and has a four digit date code
I have heard there are people out there who can rebuild and restamp that carb , but others will have to tell you who they are . Also, others will have to answer how many points you would loose for an incorrect date on an otherwise correct Carb .
Here is a picture of what I am fairly certain is the correct Carb for my 66 and for yours as well.(give or take a month or so for yours)
JimAttached Files- Top
Bob:What do you guys think about this carb on my 1966 300hp engine. It appears to be the correct carb a Holley 3367 stamp# 3884505-DA but the date code is 042(sorry i had to resize the pic and I don't think you can make out the date code) which would be April 2, 1970. Could this be correct, in Corvette by the #'s this is the right application but the date code should be 642. The author says these carbs were hand stamped and errors could occur, but my thinking is it is a replacement. My feeling is that they must have made these for other cars in the 70's. is this true? If it is a replacement how much do they ding you for the wrong date code?Let me know what you guys think. I also enclosed a copy of the intake manifold # 3872783 with casting date E116 (May 11, 1966). This appears to be correct. Sorry for some reason I can't download the pics. Thanks for any help in advance. Bob.
The date 042 translates to 1970, April, 2nd week. They used weeks instead of days for the third digit.
An incorrect date code would likely get a 20% ORIGINALITY deduction. Other ORIGINALITY deductions could apply for configuration, finish, installation, and completeness. You could also get CONDITION deductions for any deterioration and/or aging. I believe the ORIGINALITY and CONDITION points for a 1966 carb are 40 pts and 20 pts, respectively.
A 20% hit on ORIGINALITY is 8 pts.
Depends on how bad you want/need points, but if the carb functioned correctly and didn't have problems, I would leave it and enjoy driving the car. I have seen 100% correct carbs that behaved badly.....you don't need this hassle.
Of course if you work hard enough or pay enough money, you can get a 100% correct carb that works as new.
Larry- Top
