71 Lt1 - NCRS Discussion Boards
71 Lt1
  • Joe D.
    • April 30, 2002
    • 382
    71 Lt1
    Just returned from looking at a 71 Nevada Silver LT1 coupe. The car had 32,000 original miles. There were several things I did not like about the car so I decided to pass on it. Just curious, is the serial number suppose to have a "L" in it? I had seen several LT1's advertised as having a "L" in the serial number representing an original LT1. Thanks for you help, the search continues, Joe DeLuca Member 37862
  • Michael W.
    • April 1, 1997
    • 4290
    Re: 71 Lt1
    In '72 yes there was an L, but not in '70 or '71. '72 an up have a letter encoded into the VIN designating the engine type.
    What specifically did you not like about the car?
    • Joe D.
      • April 30, 2002
      • 382
      Re: 71 Lt1
      Thanks, Mike. He had changed a lot of the suspension, put a fiberglass leaf spring in the back. It had side exhaust when he bought it, he changed it back to original exhaust. The back did not have the cut out for the exhaust. He had put the piece back but it needed to be painted. The car was painted in 1980 in lacquer. It had a big scratch on the bottom of the passenger side door, about 10 inches long and pretty deep. That is the car with the 4.11 rear. The car just did not hit me. I am looking for a car that when I see it I have to have it, this car did not do it for me. It was a nice car but I guess its not for me. Thanks again, Joe
      • Michael W.
        • April 1, 1997
        • 4290
        Re: 71 Lt1
        Sounds like pretty minor 'faults' for a car that will be 39 years old soon. You might have to look long and hard to find better, but as you said if it doesn't grab you then best pass.
        • Joe D.
          • April 30, 2002
          • 382
          Re: 71 Lt1
          Mike, I am very impulsive, and it has gotten me in trouble before. I may be overly cautious now but I feel it's better to error on the sdie of caution. I have made mistakes in the past with cars, not taking my time to really look. I was one of those I'll take it guys. Only to get the car home and realize it needed more work than I thought. I am going to be 60 in December and would like to think I've finally learned from my mistakes!! Thanks again for your help, Joe
          • Wayne B.
            • September 30, 2000
            • 201
            Re: 71 Lt1
            Just curious, what was the price on that LT-1. Again, just curious, if I'm being too nosey just ignore me and I'll go away
            • Jerome P.
              • October 22, 2006
              • 607
              Re: 71 Lt1
              Do you recall the price? If so, would you share it?
              • Joe D.
                • April 30, 2002
                • 382
                Re: 71 Lt1
                He was asking 28,000. I think he was negotiable.(if that's how you spell it!)
                • Jim T.
                  • March 1, 1993
                  • 5351
                  Re: 71 Lt1
                  Joe the rear spring is one of the easiest things to change on a C2&C3. I have done it without removing mufflers/tailpipes.
                  The 81 automatics and all 82 C3 Corvettes had composite rear springs installed at the factory to replace the heavier steel ones.
                  • Mike G.
                    • July 31, 2002
                    • 709
                    Re: 71 Lt1
                    also the pannel in the back to cover up the exhaust holes is bolt on. it replaces the original rear valance pannel. easy to change. you cant tell by the vin if its a real lt1 but you can tell by several other ways.
                      • 15616
                      Re: 71 Lt1
                      You can tell by the VIN for 1972, but for 1970 or 1971 one will have to use more sophisticated methods to tell which engine the car was originally equipped with.
