1960 boot bolts - NCRS Discussion Boards
1960 boot bolts
  • Stewart A.
    • April 16, 2008
    • 1035
    1960 boot bolts
    Should my boot lid bolts that bolt to the hinge have washers on them. Mine don't have a washer and look rather uncomfortable. They have a C with a / through them. Is this correct ? Stewy
  • Stewart A.
    • April 16, 2008
    • 1035
    Re: 1960 boot bolts
    I just realised you guys call it a trunk !! Hmmmm Stewy
    • Doug F.
      • November 1, 1983
      • 322
      Re: 1960 boot bolts
      Stewart, sounds like you have the shouldered bolt, which is ok for your 60, it doesn't require washers, earlier production cars had a regular bolt, usually a TR which required flat and lock washers.
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11329
        Re: 1960 boot bolts
        .....Hmmm never knew that. Right, just saw in the 58-60 JG is says either type. Can't say I've ever seen other that TR's with lock & flats.
        Boot? ... So Stewy, do you mostly drive with the "hood"... up or down? Hopefully your bonnet's closed most of the time. Wife has a E-Type and I kid her all the time about the terminology.
        Rich
          Re: 1960 boot bolts
          Boot/trunk, bonnet/hood, hood/soft top, dizie/distributor... Yes, the common nature of the English language breaks down when you cross oceans. I've chaulked it up to another strange mystery of the sea!
          • Jim D.
            • 2884
            Re: 1960 boot bolts
            Rich
            You can't say that now. They were used on both my trunk and deck lid. Yes Stewy, they have a "C" with a line through them.
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11329
              Re: 1960 boot bolts
              Ok....thanks for the photos. Learning every day here......Rich
              • Doug F.
                • November 1, 1983
                • 322
                Re: 1960 boot bolts
                should be painted body color though right ?
                • Jim D.
                  • 2884
                  Re: 1960 boot bolts
                  Yup. Call me a "rebel".
                  • Stewart A.
                    • April 16, 2008
                    • 1035
                    Re: 1960 boot bolts
                    I forget sometimes how correct my non correct car can be. Jim big kiss for those photos. I learned 2 things the other was painted is correct. Sorry I never thought the answer would be in the JG ? I have a bolt in there that also is the same shape as the C/ but has a M on it ? Does anyone know what that bolt is M ? Stewy
                    • Doug F.
                      • November 1, 1983
                      • 322
                      Re: 1960 boot bolts
                      Stewart, as i recall M bolts don't appear until 65 or so, i have seen a few in my day but can't remember exactly where they go on a mid year, i think you'll find your M bolt is a bit shorter than the others, here are a few pics of some other original " boot " bolts from 60, 61 and 62, my super late 61 has the O with the slash. cary
                      • Stewart A.
                        • April 16, 2008
                        • 1035
                        Re: 1960 boot bolts
                        Thanks Doug for the photos. I have seen the anchor bolts before on this site but not on my car. They are an unusual looking bolt. Stewy
