Looking for an LS6 intake for my 68 - NCRS Discussion Boards
  • James H.
    • February 22, 2007
    • 130
    Can anyone help me locate an LS6 intake for my 68 427. I've heard it will work with my stock hood. Dont deal with E-bay...
    Jim
    • 43290
    Re: Looking for an LS6 intake for my 68
    Jim
    Jim------
    Why not eBay? It's your best bet for finding something like this. But, if you're dead-set against it, then I'd suggest perusing swap meets. These things turn up at the better ones (like Pomona, CA which has about 5 or 6 meets per year). If you went to Pomona, for example, and got there early, I can almost guarantee you'll find at least one for sale. Expect to pay about $350-500, though.
    As a matter of fact, I bought my first example of the 3963569 at Pomona about 20+ years ago. I paid 25 bucks for it (and my buddy wanted to try to chisel the guy down but I wouldn't let him). I've bought many more over the years [none for sale] but I can guarantee you that I NEVER bought another one again for 25 bucks. Or, anywhere near that price!
    As far as using it on your 68, it will fit under a stock 68-72 big block hood. In fact, it's one of only two square flange (Holley) manifolds ever made that will fit under a 68-72 big block hood. However, the 3963569 is a RECTANGULAR port manifold. So, it is designed only for use with rectangular port heads (i.e. only L-71 and L-88 for the 1968 model year).
    The only other square flange manifold ever made that will fit under a 1968-72 Corvette big block hood is the Edelbrock Torker II. However, this is a single plane manifold which I do not recommend for street use. It is an OVAL PORT manifold and designed to work with OVAL PORT heads (i.e. L-36 or L-68), so if you have an oval port engine, this is the only one that will work for you, single plane or not. It has no provisions for a stock-type, divorced choke.
    Incidentally, as far as spread bore (Q-Jet) manifolds are concerned, any 68-74 Corvette manifold will work for you. However, I don't know of a single aftermarket spread bore manifold that will fit. There may be one, but if there is, I'm unaware of it.
    • George C.
      • December 1, 1988
      • 583
      Jim, Saw one on ebay Sunday, going for a buy now price of $550.00. Item number:310166990292 Joe is right on the money. Good Luck. Save the Wave.
