Getting ready to install my rebuilt 427/M21 as a unit along with a new aluminum Direct Fit radiator and seal kit.  I have been told it is best to assemble the radiator and shroud to the support frame as a unit, then place in the car after the engine and transmission have been installed.
I've searched the archives and still have a question. I need to roll the car outside to use the hoist and plan on using jack stands under the frame. Does anything need to be done prior to removing the radiator support frame in order to prevent cracking some fiberglass? Do the fenders or clip need to be supported? If so, how and where?
 Removing radiator support frame
