Is this an original or reproduction big block hood? - NCRS Discussion Boards
    • May 25, 2009
    • 37
  • Rich P.
    • January 12, 2009
    • 1361
    Re: Is this an original or reproduction big block hood?
    Thats the real deal!!! Sweet hood to boot!
    Rich
    • Rich P.
      • January 12, 2009
      • 1361
      Terry,
      at second glance it is hard to tell the color of the glass. Is it black or grey. Original 67's are black some NOS over the counter (I mean 25-30 years ago) are grey with a green tinit.
      Any way it is and original hood just can't tell from the pics if it is a production line hood or an over the counter hood. Also the edge of the hood on factory hoods are filled in solid and over the counter hoods usually aren't filled with glue from the inner skin to the outer.
      Rich
      • Mike M.
        • May 31, 1974
        • 8400
        agree with rich, its not a repo but i suspect its an over the counter service replacement.nontheless, its desirable.mike
          • May 25, 2009
          • 37
          The hood was put on a 66 in the mid-seventies. The underside is gray and not black fiberglass. Is this a service replacement hood? If so, is it worthwhile to place this hood on an original car that has all its original fiberglass?
          • Rich P.
            • January 12, 2009
            • 1361
            Terry,
            I would put that on a 99+ point car for sure. I would do 2 things first. Fill the seem between the inner support and outer skin. Second clean some of the excess glue on the underside of the hood. Once the hood is painted and blacked out you will not be able to tell. Also very important don't sand the underside of the hood, strip any remaining paint with lacquer thinner and red scotch brite pads. It has great hair texture under there and you want to keep that.
            Rich
            • Wayne W.
              • April 30, 1982
              • 3605
              The rivets and the color would indicate an over the counter hood.
                • May 25, 2009
                • 37
                Wayne,
                Should I put this service replacement hood on an original car or wait until I find an original black glass hood? Or, does it matter because they are both GM hoods?
                • Wayne W.
                  • April 30, 1982
                  • 3605
                  Originally posted by Terry Mazzei (50460)
                  Wayne,
                  I dont see why it would matter much. Its real, just made at a different time.
                  • Philip C.
                    • December 1, 1984
                    • 1117
                    Hi Terry nice hood, has it been drilled for the 427 emblems? Phil 8063
                      • May 25, 2009
                      • 37
                      There weren't any holes drilled for the 427 emblems.
                      • Mike M.
                        • May 31, 1974
                        • 8400
                        lack of 427 emblem holes also favors it being a service replacement. i wouldn't hesitate to use it on a car to be judged ncrs.mike
                          • May 25, 2009
                          • 37
                          The consensus so far among NCRS members indicates it is an original GM service replacement hood. Any more thoughts from anyone regarding the originality of this hood? Your feedback is appreciated.
                            • May 25, 2009
                            • 37
                            Hi Guys,
                            Many thanks to all those who responded. Your information and expertise were greatly appreciated. I finally have a hood!
