67 BB Side Pipes - NCRS Discussion Boards
67 BB Side Pipes
  • Jim M.
    • October 20, 2009
    • 41
    67 BB Side Pipes
    Hi Everyone
    I'm kinda new to this but heard alot of good things.
    You maybe getting a few questions in the next couple of days. I apologize.
    I have a 67 BB 390hp with side pipes. I know they were installed around 1969 but unsure if they are original. Is there a part number I can look for. If so where do I look and what are the part numbers.
    Also, are they suppose to be be really loud or are they just worn out.
    Without doing my homework, I purchased new Aluminum pipes from Corvette Central but now I think I made a mistake after reading some of the communication from others as they are louder than the originals
  • Stephen L.
    • May 31, 1984
    • 3158
    Re: 67 BB Side Pipes
    If you are asking if correct looking sidepipes available in 1969 are genuine GM I'd say yes. I don't believe anyone would be repoping back then when they were available from GM.
    Brand new GM sidepipes are noisy(loud). Think about it; they are a straight thru pipe with some packing/bumps etc that exit right next to your seat.... Remember "glass paks"? Older worn out sideipes are just a little louder.......they'll never be as quiet as the new cars of today, they weren't meant to be.
    Enjoy your 67!
    • Larry M.
      • January 1, 1992
      • 2695
      Jim:
      Yes, GM sidepipes should have a part number. It should be roll stamped into the forward header pipe section that is between the exhaust manifold and the chambered muffler section. You may also see a "W" stamped there which stands for Walker (Muffler).
      The stampings are probably not real pronounced (especially after 35+ years). I located mine by jacking up the front of the car and laying on the ground looking up using a flashlight and small mirror. They were close to where the exhaust header pipe curves into the chambered section.
      Part numbers should be #3872969 (LH) and #3872970 (RH) for the big block.
      Larry
      • Wayne M.
        • March 1, 1980
        • 6414
        Originally posted by Larry Mulder (20401)
        .... GM sidepipes should have a part number. It should be roll stamped into the forward header pipe section that is between the exhaust manifold and the chambered muffler section. You may also see a "W" stamped there which stands for Walker (Muffler).
        ..... Part numbers should be #3872969 (LH) and #3872970 (RH) for the big block....
        Paid $583 Canadian (about $520 US back in March 2001) for a set of BB pipes. Never even noticed the roll stamping until this thread .
        Chromed tip is protected with factory Saran Wrap .
