C2 BB... Notch in the Inner Fender Panel to Change Plugs - NCRS Discussion Boards
  • James W.
    • December 1, 1990
    • 2658
    Was there a GM service bulletin that recommend drilling or cutting a notch in the inner fender panels on C2 big block equipped cars to aid in changing spark plugs? Why I ask is because a friend of mine filled a notched hole in the passengers side inner fender panel on his '66 427/425 coupe that he is in the process of restoring.
    Thanks in advance.
    James West
  • Hank D.
    • January 1, 1999
    • 137
    Re: C2 BB... Notch in the Inner Fender Panel to Change Plugs
    Can't say for sure with respect to a bulletin, but I do recall my departed uncle (a Chevrolet dealer mechanic in the 1960s) mentioning this method for changing plugs on mid-years (and perhaps C3s).
    • Wayne M.
      • March 1, 1980
      • 6414
      James -- haven't re-read my service bulletin indexes from the latter C2 years, but I can't remember any such instruction.
      Not to say that some mechanics wouldn't be tempted to create an access hole. But I would suspect that they would be found on C2 air cars, for cyl's # 2 and 4, under the compressor. Big blocks are MUCH easier to get to the plugs (well, maybe #6 less-so, with dipstick bracket), and any plug access holes would be at least a few inches up on the fender skirt, whereas the small blocks would be closer to the bottom of the skirt, to get a direct alignment to the plug.
      With engine off-set to the passenger side, driver side access is never a problem.
      • Jim T.
        • March 1, 1993
        • 5351
        My 64 convertible with 327/300 and factory air bought used in 1968 had two perfectly cut holes in the passenger fenderwell I used to change the two sparkplugs under the compressor.
        • Paul H.
          • September 30, 2000
          • 683
          I'm not aware of any bulletins on this. Probably the handywork of Bubba. BB plugs are alot easier to change from down under.
          • Gary J.
            • April 1, 1980
            • 1242
            I'm thinking there was an article in the Restorer a few months back. Someone may remember the issue.
