72 454 Carb - NCRS Discussion Boards
72 454 Carb
  • Dennis M.
    • April 1, 2006
    • 22
    72 454 Carb
    My 72 454 with Auto trans, came to me with a Holley with dual float chambers and dual accelerator pumps. I've been told this is a famous "Holley double pumper", that hot rodders prize.
    I beleive I've seen this type of Holley on LT-1's but not on big blocks.
    Isn't my car supposed to have a Quadrajet?
    I have been told that a Quadrajet 7042208 is correct for the car, is this true?
  • Michael W.
    • April 1, 1997
    • 4290
    Re: 72 454 Carb
    I show Qjet #7042216 for a 72 454 Corvette with auto.
    I think 7042208 is for a light truck.
    • Clem Z.
      • January 1, 2006
      • 9427
      Re: 72 454 Carb
      what is the "LIST" number stamped on the front of the holley choke tower ???
      • William C.
        • May 31, 1975
        • 6037
        Re: 72 454 Carb
        I believe you would be a lot better off with the original carb looking for a 7042216 for a Corvette '72 with 454, at least according to the '72 Service manual, and a couple of other references.
        Bill Clupper #618
        • Jack H.
          • April 1, 1990
          • 9906
          Re: 72 454 Carb
          The last Shark era BB with a Holley vs. QJet carb was the LS-6 from 1971...
          • Tom L.
            • October 17, 2006
            • 1439
            Re: 72 454 Carb
            Dennis, I have been looking for a 7042216 for my car since I bought it. Found one at Carlisle this year but opted out, $1500 and didn't have the correct date.
            For what it's worth the carb on my car is a 7042220, which I believe is the service replacement, I'm sure some will chime in. It seems to run fine with it and I have seen them on E-bay for little money compared to the correct one. Good luck!
            • Michael W.
              • April 1, 1997
              • 4290
              Re: 72 454 Carb
              7042220 is for a '72 Camaro, Chevelle, El Camino, or Monte Carlo with a 402/454 and automatic transmission
              • Dick W.
                • 10483
                Re: 72 454 Carb
                And there are vendors that can take care of the number/date deficiencies.
                Dick Whittington
                • Clem Z.
                  • January 1, 2006
                  • 9427
                  Re: 72 454 Carb
                  shame on you dick,that is not nice !
                  • Michael W.
                    • April 1, 1997
                    • 4290
                    Re: 72 454 Carb
                    Similar to starters or alternators, once a carb has gone through a recyclers and re-builders shop, the original numbers mean very little.
                    • Dick W.
                      • 10483
                      Re: 72 454 Carb
                      Part of the game Clemster I know what is wrong or restamped, you gotta find it.
                      Dick Whittington
                      • Tom L.
                        • October 17, 2006
                        • 1439
                        Re: 72 454 Carb
                        I am aware that the 7042220 was used on those engines. Does anyone know if that carburator would have been used as a service replacement under warranty or otherwise? Is it calibrated the same as the 7042216? Just curious. Thanks!!
                        • Clem Z.
                          • January 1, 2006
                          • 9427
                          Re: 72 454 Carb
                          there is not a single part in these 2 carbs that has a different part number
                          • Jim T.
                            • March 1, 1993
                            • 5351
                            Re: 72 454 Carb
                            Dennis LT-1's did leave the factory with a Holley carburator, but it was not a "Holley double pumper".
                            If you have the original intake on your 72 454 which left the factory with a QJet, a previous owner has done what other owners have done to replace the QJet with a Holley Spreadbore "double pumper" which is a direct bolt on replacement without changing the orginal intake manifold.
                            I replaced my leaking QJets on my 68 327/350 and 70 350/300 in 1974. I opted for the Holley 650 "6210 List number" spreadbore double pumpers.
                            Really like the complete positive control on when the secondarys open with the Holley double pumpers.
                            • Dick W.
                              • 10483
                              Re: 72 454 Carb
                              Clem, what about the throttle arm? Is it different
                              Dick Whittington
