1961 "Late " or Early - NCRS Discussion Boards
  • Richard P.
    • July 31, 2001
    • 173
    Would a 1961 buiild date of January 4, 1961 be considered a "Late" car or Early?
  • Mike E.
    • February 28, 1975
    • 5138
    Re: 1961 "Late " or Early
    It dependa on what component/s you are talking about. As a whole car, it is neither early nor late.
    • Richard P.
      • July 31, 2001
      • 173
      Replacing the fuel tank sending unit. The unit I received says " L61-62".
      • Doug F.
        • November 1, 1983
        • 322
        early is a threaded compression fitting, late is a slip fitting with hose clamp, see which one your car has and order accordingly. my may car has the late one.
        • Mike M.
          • May 31, 1974
          • 8388
          61 vin 4787( jan 17th, 1961 build) has comp fitting. mike
          • Ray C.
            • June 30, 2001
            • 1132
            I have a late January 61 with compression fitting and a May 1961 that does not.
            Ray
            Ray Carney
            1961 Sateen Silver 270-HP
            1961 Fawn Beige 315-HP
