1957 gas door bumper screws. - NCRS Discussion Boards
  • Bruce B.
    • May 31, 1996
    • 2930
    What is the correct screw used to hold the gas door rubber bumpers on with? What is the finish?
    I found a bag which I marked when I took the car apart and it had 2 clutch head screws in it. Are they correct. Early car #809.
  • Gary C.
    Administrator
    • October 1, 1982
    • 17678
    Re: 1957 gas door bumper screws.
    Bruce, would expect to see #6 flat head phillips in '57. Very early '57 might have had clutch same as '56 did. Gary....
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Bruce B.
      • May 31, 1996
      • 2930
      Gary,
      Thanks.
      • Steven B.
        • June 30, 1982
        • 3990
        Bruce, when I got my '57 way back when it had original fasteners and bumpers. They were as Gary said, #6 flat head phillips. The car was assembled mid-December, '56.
        Steve
        • Mike M.
          • May 31, 1974
          • 8389
          our 55 i'm just finishing up had phillps, not clutch head screws.mike
            I haven't seen every '56 and '57 ever built, but those I've restored and known originals I've observed had oval-head bright phillips screws attaching the door bumpers.
            The #431766 screw shown in the A.I.M. illustration (section E, sheet 3.00) shows very clearly as an oval-head phillips screw (that sheet was released 9/55 and shows no changes).
            • Steven B.
              • June 30, 1982
              • 3990
              I am a bit confused, and alot ignorant. Does anyone have a comparison picture of the flat head and the oval head?
              Thanks Guys!
              Steve
              • Gary C.
                Administrator
                • October 1, 1982
                • 17678
                Steve, as usual Mr. Hinckley is correct. Always thought they were flat. Pulled out my originals and they're slightly, I mean very slightly tapered on the edges when you hold a straight edge across the head. That makes them oval head. And one did show a trace of chrome on the shank. Have found clutch heads screws in '56's. Have never found the GM fastener description for the gas door bumper screw part no. 431766. Gary....
                NCRS Texas Chapter
                • Steven B.
                  • June 30, 1982
                  • 3990
                  Gary, told you I was confused--- For some unknown reason I was thinking oval looking down on it. I checked mine and they are oval looking at the side view.
                  Thanks John and Gary!
                  Steve
                  • Rod K.
                    • 443
                    #6 Oval / Phillips head on a #8 thread half inch long. Nov '56 build.
