A-arm bushing bolts re-torquing saftey issue - NCRS Discussion Boards
  • Steve L.
    • June 30, 2001
    • 763
    After the body drop, these bolts need to be torqued. But can I SAFELY remove them, one at a time, so that I can put some blue locktite on them and then torque them to spec.
    This is with the springs compressed.
    Steve L
    73 coupe since new
    Capital Corvette Club
    Ottawa, Canada
    • 15599
    Re: A-arm bushing bolts re-torquing saftey issue
    If you are talking about the bolts that thread into the end of the inner control arm shaft(s) (upper and lower) -- the ones that have the large convex washer on them -- The answer is yes, you can remove them one at a time. You can even remove all of them, but I wouldn't drive the car that way. Of course when torquing them to the final value you want the full weight of the car on the wheels.
      • 15669
      NO! And you don't need Locktite. Did GM use Locktite? No.
      With the car at normal ride height torque the bolts to the spec in the assembly manual and you are done.
      • Steve L.
        • June 30, 2001
        • 763
        Thanks for the info. My original was still tight after all this time so Locktite is probably not necessary.
        Steve L
        73 coupe since new
        Ottawa, Canada
