67 Coupe headliner repair help - NCRS Discussion Boards
  • Ara G.
    • January 31, 2008
    • 1108
    I have a 67 coupe with it's original headliner. When I got the car almost a year ago it's headliner was sagging. The prior owner I am sure wiped it with some armor all or similar product to shine it up. I have heard that putting armor all or similar products will cause the headliner to fall soon after it's application. Is there a way to repair the original headliner? I REALLY would like to NOT replace it as the interior is unbelievably original and I want to keep it that way.
    I have redone headliners in other chevy cars, with 3M general trim adhesive and the "extra" strength 3m general trim adhesive. However, I don't know if it will work and would like any help/suggestions/ideas from any of you out there. As always, any help is super appreciated. THanks ARA
  • William L.
    • December 1, 1988
    • 944
    Re: 67 Coupe headliner repair help
    Ara
    My car is also very original and did not want to change its sagging headliner but I had no luck trying to repairing to repair it. Ended up buying a repo.
    Bill
    Bill Lacy
    1998 Indy Pacecar
    • Mike M.
      • May 31, 1974
      • 8400
      the vinyl was originaly attached to the headliner assembly's FOAM . hence , ya won't have any luck re-glueing vinyl to foam. al knock is the answer. regards,mike
