I had my 093 TI distributor repaired recently. The guy that did the job informed me that the rotating pole piece that was on it was wrong and the mainshaft was wrong. I told him I definately wanted it done right and that he should replace the wrong parts with correct parts, but to return the take off parts to me as opposed to providing a credit.
The rotating pole piece had a number 236 stamped in the top of it.
When I got the distributor back a take off pole piece was in the box, but it had the number 542 stamped in it and it was on the underside. Honest mistake, right? Then I decided to investigate the distributor a little bit more and lo and behold, it has a 236 pole piece! Not mine though, this one was stamped on the underside, not the top. Are these two pole pieces functionally the same. Is there a difference between the stamped on top and stamped on the underside ones? Perhaps one is OE and the other is a service part, or worse, some sort of reproduction?
The shaft he replaced and charged me a pretty penny for has no number stamped on top as other purported originals I have seen. I did get my take off back though.
I also had a "restored" 360 can installed, but it is very different from my OEM 236 in that the nipple where the vacuum line goes on is longer, the flat surface inside of the can itself where the "plunger" meets it is gold in color, not silver and the dimples just do not look the same.
Any insight is appreciated and time is of the essence since the check has not cleared the bank yet.
