71 Stamp Pad - NCRS Discussion Boards
71 Stamp Pad
  • Erv M.
    • February 20, 2007
    • 445
    71 Stamp Pad
    I am looking at this march 71 LT1. According to the TIMJG there should be a "C" before the serial number derivative.
    This pad does not have the "C", I have attached a photo for your expert opinion.
    Is this a re-stamp or the real thing?
    I do not have the block casting number or casting date yet to reference.
  • Jack H.
    • March 31, 1990
    • 9906
    Re: 71 Stamp Pad
    The broach marks look a little deep/pronounced, but then I'm NOT a stamp pad expert. I can tell you that my '71 SB A/C base motor car DOES have the leading 'C' and it's in roughly the same time frame as what you're looking at being an April 71 build car...
    Seeing/verifying the leading 'C' is trick on an A/C equipped car due to the bolt-on component overhang (A/C stuff), but it's there alright.
    • Warren F.
      • November 30, 1987
      • 1516
      Re: 71 Stamp Pad
      I have a car close to yours in VIN sequence and it has the letter C as well. The stamping just looks a little too perfect in my opinion.
        • 3415
        Re: 71 Stamp Pad
        Hi Erv,
        Here's a picture of my 71 January built 350/270 pad. It does show the C as Jack and Warren mention. The engine hasn't been apart.
        • Dave S.
          • August 31, 1992
          • 2918
          Re: 71 Stamp Pad
          Erv,
          I own a 71 LT-1 VIN #16798. Car was built on May 11, 1971. Pad stamp is C11S116798 - V0330CGZ. Its a 5 star car so the motor is original to the car. Let me know if I can be of further help.
          Hope that helps.
          • Peter M.
            • March 31, 2003
            • 137
            Re: 71 Stamp Pad
            Dave - my 71 LT-1 engine was built 3rd week of August 70, Vin# 1149-very early 71 car. My eyes are not good but I don't see a C - I can only make out 71S101149- followed by the other numbers and cgz code - does the 71S101149 make any sense?
            Pete
            • Dave S.
              • August 31, 1992
              • 2918
              Re: 71 Stamp Pad
              Pete
              Pete,
              The posted photo starts with a 7 as we can see. I was just reporting what my engine pad has on it.
                • 15572
                Re: 71 Stamp Pad
                Take a look at the TIM&JG. The approximate VIN range of the 71S1xxxxx and C11S1xxxxx is called out. Check it out.
                • Edward M.
                  • October 31, 1985
                  • 1916
                  Re: 71 Stamp Pad
                  Pete,
                  What posted photo starts with a 7? I see two photos. One photo starts 11S, and the other photo starts C11S.
                  What am I missing?
                    • November 30, 1997
                    Re: 71 Stamp Pad
                    Scary Bubba fuel filter - rubber hoses and spring clamps on the pressure side of the pump; hope the owner has a fire extinguisher.
                    • Dave S.
                      • August 31, 1992
                      • 2918
                      Re: 71 Stamp Pad
                      What am I missing?
                      Your not missing anything. I meant 1 and typed 7. Sorry. The point of the responses is look at the Judging Guide for the answer.
                      • Erv M.
                        • February 20, 2007
                        • 445
                        Re: 71 Stamp Pad
                        I called the person which had the car for sale and notified him I was no longer interested in the car. He seemed very honest and embarrased as he truly believed he had a real car.
                        • Mark S.
                          • March 31, 2002
                          • 40
                          Re: 71 Stamp Pad
                          I use to own a 71 LT-1, 15803. Real close to this car. Mine had the C. The engine info was V0401.
