67 Rally wheel paint? - NCRS Discussion Boards
  • Henry S.
    • April 30, 2005
    • 816
    There have been several posts about getting the "correct" argent silver color for 67 rally wheels. I'm trying to restore a set, who makes the closest to the original color? Which paint will pass judging? Thanks for any input! Take care, Shooter
  • Patrick T.
    • September 30, 1999
    • 1286
    Re: 67 Rally wheel paint?
    I used the argent silver on my '67 Rally wheels from Long Island Corvette Supply and they passed on judging for me. I can't guarantee that it will work for your wheels though. Every Judge is different. PT
    • Henry S.
      • April 30, 2005
      • 816
      Thanks Patrick.
      • Timothy B.
        • April 30, 1983
        • 5177
        I am getting ready to paint my 67 rally's, the original color almost looks like flat dull silver.
        • Brian M.
          • January 31, 1997
          • 1837
          I used the above mentioned paint and feel it came out too flat, judges also mention "too flat" on judging sheets, Maybe I sprayed it from too far away.
          • Chris E.
            • November 2, 2006
            • 1322
            The Long Island Argent silver used over my sanded and cleaned original rally wheels turned out more bright than I expected. But, once the wheels were on the car (read as, vertical and not horizontal thereby reflecting more of the sunlight) the color looks great.
            My car when through two Chapter meets without any mention of the shade of the silver, right Tony?
            Chris Enstrom
            2011 Z06, red/red
            • Craig O.
              • July 31, 1983
              • 207
              here is a PPG formula that you can give to your local dealer . I have used it and think it is very good in color.... Argent Silver DAR 8568
              One Quart
              DMR 433 416 units
              DMR 435 420 units
              DXR 495 30 units
              DMR 499 160 units
              • Timothy B.
                • April 30, 1983
                • 5177
                Does anyone know if the original Argent color is lacquer or enamel..
                • William C.
                  • July 15, 2009
                  • 239
                  Dupont Lucite Acrylic Lacquer, 9692L Argent
                  Silver.
                  • Timothy B.
                    • April 30, 1983
                    • 5177
                    Thanks William,
                    Is this what you painted your 67 rally's with?? Are you satisfied with the color?
                    • William C.
                      • July 15, 2009
                      • 239
                      Tim,
                      The color and gloss is correct. I have used it on 2, 67's and 1, 69. Some of these rattle cans are to flat or the color is off. You understand this has to be sprayed with a gun.
                      Bill
                      • Kirk M.
                        • June 30, 2006
                        • 1036
                        Don't forget that the inside of the rim should be black with silver overspray from the openings. You might prime in black and then spray the silver argent on the fronts.
                        Kirk
                        • Craig O.
                          • July 31, 1983
                          • 207
                          It was enamel
                          • Henry S.
                            • April 30, 2005
                            • 816
                            Originally posted by Craig Olson (6815)
                            It was enamel
                            Yes, I was thinking I had seen a post on the Camaro forum from John Hinckley that said the original was enamel.
                            • Timothy B.
                              • April 30, 1983
                              • 5177
                              When enamel is mixed don't they add clear thus making the color to glossey for these wheels.
