1960 Wheels... welded or rivited? - NCRS Discussion Boards
  • Valeria H.
    • July 27, 2009
    • 463
    #31
    Re: 1960 Wheels... welded or rivited?
    Dennis,
    Thanks for your photos. Mine are definately dogbone but are they KO's is the question.
    Valeria
    Valeria Hutchinson
    Past Chairman of the Carolinas Chapter
    1960 Roman Red w/ White Coves -"Bella"
    2005 Millennium Yellow 6 speed 400 HP - "Trixie"
    • Valeria H.
      • July 27, 2009
      • 463
      #32
      I think I finally mastered the photo posting. I was making it way more difficult than it is. I believe this is a dogbone but can anyone tell me if they are real or KO's.
      I know now that the person I contracted to paint the wheels should have painted the inside black. I'll have to have them repainted. Also, does it matter if the area where the tire is applied is painted or not?
      Valeria
      Valeria Hutchinson
      • Dan A.
        • May 31, 1974
        • 1073
        #33
        The date code in the picture posted appears to be January 1962.
        The photo of the backside of the wheel is at an angle that combined with the gloss makes the area of the spyder that is welded to the outer rim difficult to see clearly. Even with blowing the photo up. My best guess is that it is fuse welded which you want and does not have the dog bones. I am of the school of thought that I woudl not want to see dog bones on a 62 wheel that was originally installed on a Corvette. I also have the same opinion for a 1960.
        What do you mean by the term KO? Are you refering to an after market part. KO's are generally thought to be optional aluminum wheels available from 1964 through 1966 known as knock offs due to their method of attachment.
        A clear picture of the face of the wheel would be helpful.
        Dan
        • Dennis C.
          • June 30, 2002
          • 884
          #34
          I agree, with the photo posted it is hard to see. However, if you are looking for wheels with dogbone cut outs, this doesn't appear to be what you want.
          Try taking a photo in natural light without the flash. Or even just a picture of the welded area.
          Dennis
          Last edited by Dennis C.; January 16, 2010, 05:02 PM. Reason: spelling correction.
          • Dan A.
            • May 31, 1974
            • 1073
            #35
            This is a dog bone inside the retangle
            • Dan A.
              • May 31, 1974
              • 1073
              #36
              Close up of a dog bone in the second photo. First photo is a KO.
              • Dan A.
                • May 31, 1974
                • 1073
                #37
                explanation of stamps found on the rim between the beads (location where tire is seated) or inside whena tire is mounted.
                • Dan A.
                  • May 31, 1974
                  • 1073
                  #38
                  You want to see this GM stamped on the face side of the spyder on one of the rises between the lug nut stud holes. You also want the vavle stem hole to be 5/8ths of an inch.
                  • Valeria H.
                    • July 27, 2009
                    • 463
                    #39
                    Daniel, I'll post a photo of the front of the wheel. I was concerned that they were repo's and not the original wheels. Unfortunately, I wanted 1960 wheels. JT got me!! This does not make sense as he advertised a 1960 orginal Kelsey Hayes wheel on e-bay and I purchased the wheel and asked if he had 4 more. Looking at all of them, they are all January 62.
                    Are the 60 wheels much different than the 62's that I have?
                    I guess the only dated wheel that really matters is the one in the trunk.
                    I hate being taken!
                    Would it help if I removed some of the paint from the logo area?
                    Valeria
                    Valeria Hutchinson
                    • Dan A.
                      • May 31, 1974
                      • 1073
                      #40
                      ..........and you want to see this contour (where I have placed a red rectangle and an arrow) as opposed to more of a 90 degree at the meeting of the two planes if the wheel you want was originally mounted on a Corvette at the the time of assembly at St. Louis. The nubs that retain the full wheel discs you should already know about.
                      Further beacause you have painted the rim faces body color it should be safe to assume you plan to mount black wall tires on these rims.
                      • Dan A.
                        • May 31, 1974
                        • 1073
                        #41
                        • Valeria H.
                          • July 27, 2009
                          • 463
                          #42
                          Daniel, I do have the GM stamp on all 5 of the wheels but only one is really clear. The other 4 are present but faint. I also so have that hump you red boxed on your photo. I now feel certain these are C1 corvette wheels. As you and I have both pointed out, the painting of the wheels is all wrong and will need to be corrected.
                          When I pruchased the wheels from JT Piper I had the wheels sent directly to the man who did the body work and painting on my car. JT said he would include specific painting instructions with the wheels. I should have researched exactly what needed to be painted and how but I did not.
                          I really wanted the white wall tires which I have not purchased yet.
                          I will need to take the wheels to a painter who really knows vintage corvettes. What does the rim look like with a 2 1/2 inch white wall which is my perferred tire?
                          Thanks for your patience and you help,
                          Valeria
                          Valeria Hutchinson
                          • Tom D.
                            • September 30, 1981
                            • 2137
                            #43
                            All four of my dated 1960 welded wheels, on a three owner white car, were still painted white when I acquired the car. The dates inside the wheels all match with the production date of the car, well within NCRS guidelines. In fact, most of the white paint on the car was original before I started the first restoration.
                            I have seen other dog bone wheels, and don't recall any dog-bones inside these 1960 rims. To be sure, I will be glad to take some photos. There is no question in my mind; These are the original rims. (It's a March, 1960 Car.)
                            By the way, I found this discussion because I was looking for comments on the white Corvette in the 1960 Sales Brochure. It has red rims on a white car...
                            Thanks for all your comments. Tom D. (4889)
                            https://MichiganNCRS.org
                            Michigan Chapter
                            Tom Dingman
                            • Tom D.
                              • 2137
                              #44
                              My 1960 dates are only on the inside of the rim. Your red wheel appears to have the right shape on the front side.
                              Michigan Chapter
                              Tom Dingman
                              • Doug F.
                                • November 1, 1983
                                • 322
                                #45
                                went through my stash of wheels, didn't list any duplicate dates and only listed if the date was easily readable, here are the dates for the non dogbone wheels 6-59, 6-60, 3-61, 6-62, the wheels with cut outs are dated 4-56, 5-56, 8-56 and 1-57, anyone else see a pattern here ??
