1968 Wiper Door - NCRS Discussion Boards
1968 Wiper Door
  • Nicholas R.
    • October 18, 2009
    • 18
    1968 Wiper Door
    Hello, I'm new to the NCRS. I just purchased my first Corvette. (1968 coupe) The previous owner removed the entire wiper door assembly. I purchased all the parts except the knobs under the dash, and the valve behind the tach. I'm not sure which ones I need, if not all. Also I don't know what the valve is that mounts under the wiper door, or if it's correct for a 1968 corvette. If anyone can help with information, Thanks!
  • Jack C.
    • September 30, 1992
    • 1090
    Re: 1968 Wiper Door
    PM sent today.
    Jack Corso
    1972 Elkhart Green LT-1 Coupe 43,200 miles
    Top Flight 1994, 2018 & 2021
    • Patrick N.
      • March 10, 2008
      • 954
      Re: 1968 Wiper Door
      Welcome Nicholas to NCRS, I'm new too and also have a 68. I am part way through a restoration, my dash is out but my wiper door is intact. Let me know if you need photos. Jack has helped me out before with pics of his car-found it to be very helpful getting things sorted out.
      Good Luck,
      Pat
      68 427/400
      88
        • 3415
        Re: 1968 Wiper Door
        Hi Nick,
        Just want to say hello and welcome! I'm glad to have another member interested in 68-72 cars.
        I'm always interested in seeing pictures of what people are working on and enjoying.
        • Nicholas R.
          • October 18, 2009
          • 18
          Re: 1968 Wiper Door
          Hi Alan, Thanks for the email. If you have pictures, I would really like to see them. I'll be happy to send you any pictures of mine you may need as well. Real life pictures is one of the best ways for me to put things back together. Thanks again, NICK
          • Kurt B.
            • July 31, 1996
            • 971
            Re: 1968 Wiper Door
            Nicholas,
            Welcome to NCRS and congratulations on having a 68.
            This is a great place to get help with all your questions.
            While restoring my 68, I used this site as much as I used my Assembly Manual.
            Post some pictures when you have a chance
            Kurt
            68 Coupe
            • Mark F.
              • January 1, 2003
              • 139
              Re: 1968 Wiper Door
              Welcome from another 68 BB Coupe owner.
              Mark
              • Patrick N.
                • March 10, 2008
                • 954
                Re: 1968 Wiper Door
                Hi Nicolas,
                Sorry for getting back late on this-missed your request. Hope these still help. Did not see a valve under my wiper door- all mechanical linkage (my car is a March 68 car) washer valves are tiny tubes attached to bottom of grile in front of door.
                Attached are images of my wipper door.
                • Jim T.
                  • March 1, 1993
                  • 5351
                  Re: 1968 Wiper Door
                  Originally posted by Patrick Nolan (48743)
                  Hi Nicolas,
                  Patrick from picture #1 it appears there is no wiper arm acutated vacuum valve that functions as when the wiper door will close.
                  Look on the wheel well area above the windshield washer fluid container for a vacuum relay, this is also functions with the wiper door operation.
                  In picture #3 the phillips screw that is in the bracket arm into the wiper door is not original. A shouldered bolt with white plastic washer that you have in front of this is what should replace the phillips screw.
                  Hope this link works from Volunteer Vette, it will show the pieces I have mentioned. http://www.youblisher.com/p/2303-No-Title/ It is on page 160. Using the roll function on your mouse will turn the pages in the catalog. Double click to enlarge when you get to page 160. The mounting bracket for the wiper arm actuated vacuum valve is also available.
                  • Terry B.
                    • August 31, 1999
                    • 607
                    Re: 1968 Wiper Door
                    Nicholas,
                    Welcome to the '68 fraternity! This is a great place to get your questions answered. I want to repeat Kurt's comment about purchasing a '68 Assembly Manual. It has drawings that will give perhaps that view that a picture from one of us will not be able to show. I look forward to seeing pictures of your '68 as you go through the restoration process.
                    Terry Buchanan
                    Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
                    Corvettes Owned:
                    1977 Coupe
                    1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
                    2003 Electron Blue Coupe
                    2019 Torch Red Grand Sport Coupe
                    • Michael D.
                      • June 30, 1996
                      • 536
                      Re: 1968 Wiper Door
                      Originally posted by Nicholas Rao (50928)
                      ...(1968 coupe)...I'm not sure which ones I need, if not all....
                      You will need the solenoid on the back of the tach. It sends a vacuum signal to open the wiper door when you push the Wiper switch. The vacuum switch under the dash holds the wiper door open for maintenance.
                      The electrical switch under the dash is the wiper override and stops the wipers on the windshield to allow for changing wiper blades, etc.
                      As others have suggested, order the '68 assembly instruction manual (AIM).
                      Welcome.
