Another Holley 3810 Project - NCRS Discussion Boards
  • Gerard F.
    • June 30, 2004
    • 3806
    Well, I'm about to begin a restoration project on this Holley 3810:
    Just about everything is wrong on this carb for a 3810, the fuel bowls, base plate and throttle, 50cc accelerator pump, #19 secondary metering plate, choke lever. I think most of the parts came off a 66 passenger car.
    The #19 metering plate is for a 327 275hp engine List 3230A.
    But I just couldn't pass this one up for my 67 327/300:
    The date code 763 on the air horn is the week before my 06/26/67 engine. The main body and the 4743 metering block are the only things on this carb that are correct to a 3810. Does anyone recognize the float adjusting screws/nuts? They look very odd to me.
    So in the next few months we will go through a restoration of this carb back to factory. I'll keep you posted.
    Maybe someday, it will look like my date coded 751 3810 currently on the car:
    Jerry Fuccillo
    Re: Another Holley 3810 Project
    Jerry -
    I've seen those thick float adjusting nuts (vs. the thin Holley nuts) in some off-brand aftermarket needle-and-seat kits.
    • Brian M.
      • February 1, 1997
      • 1840
      Are you going to use the non external float adjusting bowls?
      • Dale S.
        • November 12, 2007
        • 1224
        Those float adjusters look like the adjusters on a "Champion Parts Rebuilders" rebuilt Holley I have. Dale
        • Gerard F.
          • June 30, 2004
          • 3806
          Brian,
          I have the bowls from a service dated 3810. That service dated holley will then become a driver 3810 with the bowls off this one.
          I also have an original throttle plate stamped 3810 which will go on this one.
          Regards, will see you in Florida in January.
          Jerry Fuccillo
