040 Head Application? - NCRS Discussion Boards
  • Mark P.
    • July 31, 2003
    • 407
    I don't think this is a Corvette application, but does anyone know what car and engine an 040 head with a right triangle marking (as opposed to a pyramid) was used on?
    Any help would be appreciated.
    Mark
    Mark Pugmire
    54 Pennant Blue
    56 Cascade Green Dual Quad
    56 Arctic Blue Dual Quad
    66 Nassau Blue 427 L36 Convertible
    67 Marlboro Maroon L79 Coupe
    • 43290
    Re: 040 Head Application?
    Mark
    Mark-----
    The casting number was 3947040. It was a 64cc cylinder head used in trucks with 327 cid engines in the 68-69 period.
    • Mark P.
      • July 31, 2003
      • 407
      Thanks, Joe. Once again, you're the man with the answers. I appreciate your help.
      Mark
      Mark Pugmire
      54 Pennant Blue
        • 43290
        Mark
        Mark-----
        By the way, there was a similar head with and identical "right triangle" casting symbol used on Corvettes. It was GM casting number 3947041. It was used on some 1969-70 Corvettes with base engine or L-46 and was manufactured into finished heads with both 1.94/1.50 and 2.02/1.60 valve size. It was also used on other 1969-70 Chevrolet applications.
        So, what was the difference between the 3947040 and 3947041 castings? I believe the difference was that the 3947040 used 1.72/1.50 valve size and hardened exhaust valve inserts.
