54 choke - NCRS Discussion Boards
54 choke
  • Brad H.
    • August 12, 2007
    • 724
    54 choke
    My choke pulls out very hard, What is the tension on these and how to loosen it up, thanks, Brad.
  • Roy B.
    • February 1, 1975
    • 7044
    Re: 54 choke
    Have you tried WD40 on the cable housing
    • Brad H.
      • August 12, 2007
      • 724
      Re: 54 choke
      Hi Roy, do you mean take cables off and Squirt down entire inside of each one? Don't want to take them apart in fear of having to adjust carbs again if I don't have to. Thanks Brad.
      • Roy B.
        • February 1, 1975
        • 7044
        Re: 54 choke
        Yes try squirting the housing as you pull and push in the choke, and add some down the handle cable area good luck
        • Brad H.
          • August 12, 2007
          • 724
          Re: 54 choke
          Thanks Roy, will give that a try. Brad.
          • Steven N.
            • April 30, 2002
            • 214
            Re: 54 choke
            Brad,
            I spray the cables with silicone spray and then I pull the choke out and put gear cutting oil on the rod and then push and pull out several times. Works great and will ease the tension. Also check the cables for proper installation. Thanks........Steven J..........
            • Cathy S.
              • August 31, 2003
              • 293
              Re: 54 choke
              Try some cable ease. It works well and can be purchased from corvette central.
              • Brad H.
                • August 12, 2007
                • 724
                Re: 54 choke
                Originally posted by Steven Neel (37940)
                Brad,
                Steve, are you saying you can spray right on the sheathing of the cables and it will go through them and lube the cables inside or disconnect everything and spray down each sheath to lube? Brad
                • Steven N.
                  • April 30, 2002
                  • 214
                  Re: 54 choke
                  Brad,
                  Yes, just put a rag behind cable and spray short sections of it moving the rag for each section, siliccone will find its way. Then just put oil on choke rod and work it in to the assembly. Has worked fine for me .
                  • Brad H.
                    • August 12, 2007
                    • 724
                    Re: 54 choke
                    Thanks guys, gals, that did work pretty darn good. Again Brad.
                    • Steven N.
                      • April 30, 2002
                      • 214
                      Re: 54 choke
                      Brad,
                      What did you end up using ?.
                      • Brad H.
                        • August 12, 2007
                        • 724
                        Re: 54 choke
                        Hi Steve, sorry comp. was in need of repair, I siliconed the cable housing then just put oil on the rod, it was twice as easy then but now I niticed it is getting stiffer or harder to pull out again, seems the rod maybe is tight in the housing as it pulls out so I must see how to loosen up ? Anybody? Thanks, Brad.
