1969 Ignition shield ground tab - NCRS Discussion Boards
  • Kenny C.
    • March 2, 2009
    • 191
    On the distributor box there is a ground tab that makes contact with the air cleaner base or is it supposed to contact the lid? I am installing this as a new replacement so I have no old one as a reference. The box has multiple holes to mount the tab. In looking this up in the archives and in the aim but it seems that the tab can be mounted top set or lower set facing up or down depending in the engine and air cleaner configuration. The problem is I cant seem to find how to determine which is which. My car is a 350 L46 and all stock can anyone tell me the proper hole location and direction to install the ground tab. Also while I'm at it how the hell are you suppose to install those rivets? Thanks in advance
    Regards
    Kenny
  • Michael B.
    • June 18, 2007
    • 400
    Re: 1969 Ignition shield ground tab
    The grounding tab is mounted using the top 2 holes and extending downward for all but the 3X2 air cleaners that mount in the bottom 2 holes and extends upward.
    You should be able to use a vise or body dolly to use as a bucking bar and tap the rivets down with a hammer.
    • Kenny C.
      • March 2, 2009
      • 191
      Michael
      Thanks for the input, that makes sense i don't know why that its not pointed out better in the AIM or maybe it is and I just didn't find it.
      Kenny
