Steering gear lubricant - NCRS Discussion Boards
  • Jake D.
    • August 31, 1984
    • 134
    What do you guys recommend to use as a steering gear lubricant? I am rebuilding a '62 steering box, and don't know what lube to use in it. Should I use chassis grease, or pour in some 80-90wt. gear lube?
  • Larry M.
    • January 1, 1992
    • 2695
    Re: Steering gear lubricant
    Jake:
    At the bottom of the page is a listing of five similar steering box lube questions others have asked. The answer(s) you seek are in these posts, along with a lot of details/explanations.
    The short answer is GM chassis lube #12377985 or equivalent.
    Larry
    • Jake D.
      • August 31, 1984
      • 134
      Thanks Larry- I have some Mobil 1 chassis grease, and I have used it in the spindle bearings of my '67. There is over 20,000 miles on those bearings, without a wimper from them. I was wondering if I should put some 80-90 wt. gear oil in the steering box, but as you suggested, I'll get on over to my local Chevy dealer, and buy some chassis grease.
