How do I tell the original interior colour of my C1 - NCRS Discussion Boards
  • Stewart A.
    • April 16, 2008
    • 1035
    Is there any tell tail signs of an original interior colour for a 1960 ? Stewy
  • Gary C.
    Administrator
    • October 1, 1982
    • 17681
    Re: How do I tell the original interior colour of my C1
    Stewy, Noland Adams and Roy Braatz wrote an article a long time ago about 58-60 having green crayon colors written on the bulkhead wall behind the trunk Division panel. Recall it was on the right hand side by the hinge spring? Maybe Roy or other folks will provide more info for you. Gary....
    NCRS Texas Chapter
    https://www.ncrstexas.org/
      • May 31, 1974
      • 8389
      the Noland/Roy crayon marking article dealt with EXTERIOR C-1 color. mike
      • Bill M.
        • April 1, 1977
        • 1386
        There is overspray under the carpet that may give it away. On my '59, you could see where the radio block-off plate was set on the floor and sprayed (plate red, interior panels white).
        • Roy B.
          • February 1, 1975
          • 7044
          Knowing how to tell the body color as Noland and I wrote about can help decide the interior color bast only by the body color combination that was offered .So you may have a choice.
          • Stewart A.
            • April 16, 2008
            • 1035
            The exterior panel colour has always been an easy find but the interior colour has me baffled. Was the steering column and bezel painted out of the car ? What was painted in the cabin interior colour that I could inspect ! Stewy
            • David D.
              • December 1, 1977
              • 231
              Look for overspray in areas of the console, above and below. The floorboard sometimes shows overspray at the base of the console. If the car has had a few repaints, you may need to strip the paint until you get to the bottom coat.
              David Dawdy
              • Stewart A.
                • April 16, 2008
                • 1035
                Yeah the console should be a good place to have a look at. I will have a wee looky. Stewy
                • Steven B.
                  • June 30, 1982
                  • 3990
                  Stewy, unless someone stripped all of the interior paint there should be signs of original paint near the instruments, steering column, hub, etc. Try scrapping or rubbing to the original paint.
                  Steve
                  • Bill M.
                    • April 1, 1977
                    • 1386
                    Here's a picture of the red console overspray on the white body color of my '59. I think this is the only place where there would be red paint over the white if your car had a radio. The radio block-off plate was sprayed on the floor of the car if your car didn't have a radio.
