C 2 fuel gauge problem - NCRS Discussion Boards
  • Jim R.
    • June 30, 2001
    • 643
    Hi guy's my fuel gauge only works from full to 7/8 ,once the fuel goes below 7/8 thats it the gauge stay's at 7/8 and the the fuel keeps going, then once i fill up again it will then return to full, but again stop at 7/8 . anyone have any ideas what i can look for, this happened after sitting ,one day it worked then the next it didn't.....jim
    Re: C 2 fuel gauge problem
    Jim -
    Although it sounds like either the sending unit float arm is stuck or the wirewound resistor has gone south, perform the diagnostic routine you'll find at the link below to isolate the problem.
    http://www.lbfun.com/warehouse/tech_...rFuelGauge.pdf
    • Mark P.
      • July 31, 2003
      • 407
      I had the same problem with my 66. I replaced the o-ring seal and then it didn't work after previously working fine. I posted the question and John Hinckley posted the same tech diagnosis options and I found out that unit had indeed gone south. I replaced it and it works great. Ran out of gas a couple of times before it was fixed, now my wife trusts it enough to go out on rides with me again. Still working on her trusting me...
      Thanks again, John!
      Mark
      Mark Pugmire
      54 Pennant Blue
      56 Cascade Green Dual Quad
      56 Arctic Blue Dual Quad
      66 Nassau Blue 427 L36 Convertible
      67 Marlboro Maroon L79 Coupe
      • Jim R.
        • June 30, 2001
        • 643
        Thanks john, it looks like my sending unit is bad.....jim
