Holley Fuel Inlet Fitting - Wrench? - NCRS Discussion Boards
  • Jack O.
    • July 31, 1996
    • 527
    Hi everyone,
    My Holley started leaking at the fuel inlet. I removed the fuel line to tighten them but can't get anything to fit. It takes a 1 inch wrench but I can't get anything to fit - socket, open/box end wrench - they all hit the fuel bowl. I even tried putting a fitting in the inlet so I could use a smaller socket but it doesn't tighten the inlet, only the fitting itself. Then there's the problem of getting the fitting off without loosening the inlet. Any suggestions? Is there a special tool made for this?
    Jack
    Jack Ottofaro
  • Ray G.
    • May 31, 1986
    • 1189
    Re: Holley Fuel Inlet Fitting - Wrench?
    Originally posted by Jack Ottofaro (28026)
    Hi everyone,
    Jack
    Hello Jack;
    There are thin wrenches available.
    Have a 1" wrench about .125 (1/8") thick.
    Not close to my tools at this writing, but believe it's a MAC.
    Email if you can't find a supplier.
    Regards.
    Ray
    I hope you dance
    • Jack O.
      • July 31, 1996
      • 527
      Thanks Ray. Did you use an open or box end?
      Jack Ottofaro
      • Mike M.
        • May 31, 1974
        • 8402
        grind material off the sides of a 1" open end wrench such that the wrench will grab the fitting without damaging the holly.mike
        • Wayne M.
          • March 1, 1980
          • 6414
          Here's another link from last June that discusses bowl fitting solutions.
          https://www.forums.ncrs.org/showthre...inlet&uid=9817
          • Clem Z.
            • January 1, 2006
            • 9427
            buy a open end 1" wrench that the opening is 90 degrees to the handle or make one
