Can I replace the battery compartment on a 1974 Coupe - NCRS Discussion Boards
    • 15631
    Re: Can I replace the battery compartment on a 1974 Coupe
    Originally posted by Vinnie Peters (17535)
    Was in the Spring 2016 issue but it was storage compartment door and hinge restoration, not the box
    Didn't Scott Sinclair do a story about spare tire tub restoration that contained information about coloring resin and adding the fiber threads?
    • Vinnie P.
      Editor NCRS Restorer Magazine
      • May 31, 1990
      • 1576
      Terry, you are correct, will have to look for that one as it's a few years ago...I was only reading about the storage compartment, not the fiberglass work...my bad
      • Vinnie P.
        • May 31, 1990
        • 1576
        #18
        Found it...was in the Spring 2008 issue, which was the first full color issue of The Restorer. If anyone wants a pdf of the article Terry refers to here's a link to it...
        Vinnie
          • 15631
          #19
          Found it...was in the Spring 2008 issue, which was the first full color issue of The Restorer. If anyone wants a pdf of the article Terry refers to send me an email please restorereditor@ncrs.org
          It is a good thing you have electronic files. That is farther back than I would have thought. Time flies when you're having fun.
