Can I replace the battery compartment on a 1974 Coupe - NCRS Discussion Boards
  • Dan T.
    • July 2, 2009
    • 13
    I just bought a 1974 L82 Coupe and it appears that the previous owner ran over something and it badly damaged the battery compartment. A large portion of the fiberglass was ripped off and there seems to be some sheet metal exposed. This may have been added to hold the battery in. Can I replace the battery compartment or do I have to have it re-fiberglassed? I don't think it is safe to drive as is.
    Thanks. Dan
  • Don G.
    • March 1, 1989
    • 251
    Re: Can I replace the battery compartment on a 1974 Coupe
    If you have extensive damage and missing fiberglass, you may want to consider finding a donor clip and have a body shop replace the section.
    You might start by determining what years have a common design and then check ebay for a rear clip from one of those years. You can also check with Corvette salvage yards. Since you are only looking for the battery compartment, you can keep the price down by finding an otherwise badly damaged rear clip. The bigger challenge is to find someone who can patch it in without it looking like it was patched in.
    Good Luck.
    • Gary R.
      • April 1, 1989
      • 1799
      Yes they can be done, basic fiberglass work. I did my 69 box years ago. They get damaged from broken u-joints or battery acid.
      • Dan T.
        • July 2, 2009
        • 13
        If I were to go the route of buying a compartment from a salvage operation would I be able to install that without taking the body off. From looking at it from below all 3 compartments seem to be one piece. I would hope that there would be a seem towards the back and one right by the seats. Any clue about this?
        • Harmon C.
          • August 31, 1994
          • 3228
          Any of the Corvette bone yards should have a battery box. I cut the bottom two inches off on one car and the doner. Cliped it on the four corners with small metal strips. With the spliced area ground out I glassed it in. I then removed the metal strips and glassed the corners. I finished the area smooth and blended in some light undercoat to match the wheelwell.
          It has four sides and can be done on the car.
          Lyle
          • Dan T.
            • July 2, 2009
            • 13
            I'd like to thank everyone for the input. This is great because I am new at this and have the drive but not the knowledge. I have found 2 donor parts that I am negotiating on now and will splice it on. Thanks to all.
            Dan
            • Dan T.
              • July 2, 2009
              • 13
              When you say the spliced area is ground out do you mean that it is sanded down so the they merge better? If you could explain in laymans terms that would help. Thanks.
              • Mark E.
                • April 1, 1993
                • 4597
                I'm planning to replace the battery box in my '70 using a good used box from a donor car. I've done this before on another car (a '73 which also had a battery box eaten by acid) with good result.
                My question is what's the best method for matching the original fiberglass finish? Is it just gel coat or is it also painted? Is there a specific color or tint?
                Thanks guys.
                Mark Edmondson
                Dallas, Texas
                Texas Chapter
                • Russ S.
                  • April 30, 1982
                  • 2162
                  You grind both pcs in a concave extending about one inch on each, butt them up and glass.
                  Originally posted by Dan Taifer (50587)
                  When you say the spliced area is ground out do you mean that it is sanded down so the they merge better? If you could explain in layman's terms that would help. Thanks.
                  • Mark E.
                    • April 1, 1993
                    • 4597
                    Russ,
                    Thanks for answering Dan's seven year old question.
                    I still would like to know how to refinish the fiberglass (post #8).
                    Mark Edmondson
                    Dallas, Texas
                    Texas Chapter
                    • Mark E.
                      • April 1, 1993
                      • 4597
                      Thanks guys.
                      Any advice?
                      Mark Edmondson
                      Dallas, Texas
                      Texas Chapter
                      • Mark E.
                        • April 1, 1993
                        • 4597
                        My question is what's the best method for matching the original fiberglass finish? Is it just gel coat or is it also painted? Is there a specific color or tint? Thanks guys.
                        Can one of you help with this? I guess I can ask a couple of Corvette restoration shops and post the responses.
                        Mark Edmondson
                        Dallas, Texas
                        Texas Chapter
                        • Jimmy P.
                          • June 24, 2014
                          • 1696
                          Russ,
                          Hi Mark,
                          l feel your pain, with not getting an answer. However, I also had to do some repair work on my 73 battery box. My corner where the negative cable passes thru was gone from corrosion. I too was searching to find a close match to the original fiberglass finished appearance. But really, like you didn't have much luck. I did read (can't remember where,and didn't keep it) something where a guy tried spattering some gray/white paint over the dark gray base color trying to simulate the look. I attempted it but it was next to impossible to do under the car, so I abandoned it and just sprayed undercoating on the repair for now. I'm sure there is someone out there with the answer, can't believe no one on here as tried to accomplish this.
                          Mark, maybe you should start this as a separate new thread? These guys are seeing battery compartment replacement on a 74. Not seeing your issue. I'd be interested too! Just a thought,��
                          Sorry I could more of help,
                          Jimmy
                          Jimmy
                          1973 Convertible
                          L48,M20,N40
                          Mille Miglia Red/Oxblood
                            • 15613
                            Originally posted by Jimmy Patitucci (60161)
                            Hi Mark,
                            Jimmy
                            I am pretty sure I saw an answer to this issue in a Restorer article about spare tire tubs a year of two ago. I didn't pay a whole lot of attention to it because I don't have the need of that technique. You might want to check the last couple of years of Restorer issues.
                            • Vinnie P.
                              Editor NCRS Restorer Magazine
                              • May 31, 1990
                              • 1571
                              Was in the Spring 2016 issue but it was storage compartment door and hinge restoration, not the box
