Alternator - NCRS Discussion Boards
Alternator
  • Richard M.
    Infrequent User
    • October 22, 2006
    • 28
    Alternator
    Need help determining the correct alternator for a 63 327/340 hp engine.
  • Harry S.
    • July 31, 2002
    • 5333
    Re: Alternator
    Rich, 1100628 37A should be the number. Be careful as the passenger car had the same number except they are physically different. The passenger car alternator had a round hole in the back to attach a clip that held the harness. The Corvette alternator had all rectangular openings, no hole for a clip. Also, best I can recall all the identification info like date code was in the same area as the 1100628. On my 63 my alternator is dated 3 weeks prior to the car build date.
    Good luck.
    • Richard M.
      Infrequent User
      • October 22, 2006
      • 28
      Re: Alternator
      many thanks
      • Timothy B.
        • April 30, 1983
        • 5198
        Re: Alternator
        Richard,
        Not to steal Harry's thunder but the early 628's including passenger car has the rectangular holes without a hole for the wire harness attachment plug. Early alternator's also have the part # and date stamped on the back half flat area, not behind the adjustment bolt like typical mid 63-up alternators.
        I can post a pic later if you need one. Look in the archives for discussion and in the JG for the changover time frame.
        • Brandon T.
          • October 23, 2008
          • 872
          Re: Alternator
          Let me know what date you need I happen to have one and it's been restored and tested.
