Gas tank removal - NCRS Discussion Boards
Gas tank removal
  • Dave C.
    • March 1, 2004
    • 82
    Gas tank removal
    Does anyone have simple directions for a tank removal in a 66? Is it difficult? I'm handy but always get scared I'll get it apart and screw up something?
  • Steven B.
    • June 30, 1982
    • 4000
    Re: Gas tank removal
    Dave, I remember reading the past months in the Archives some step by steps. I did my '77 about 12 years ago and it is not that bad. As I recall I emptied the tank, put it on jack stands AND blocks, removed the tire carrier, I removed the flap around the cap, removed the wiring on top of the tank, supported the tank from below on a floor jack and stands, unbolted the straps, and brought it down to the floor easily while lying on my back.
    You aren't going to mess anything up.
    Steve
      Dave -
      There's an illustrated step-by-step procedure in the Chassis Service Manual; if you have a coupe, the filler neck must be removed from the tank first.
        • 11669
        Removing it is easy.
        It's the reinstallation that is a bear.
        Been there, done that, at least 3 times.
        • Donald O.
          • May 31, 1990
          • 1593
          Steve
          What wiring on the top? On my 67 and the 64 I used to have the wiring is on the bottom at the fuel meter.
          But I agree with the rest of your instructions, I just replaced the metering unit in my 67 over last winter.
          Dave, replace your metering unit to fuel line hose as well. They're 43 years old too maybe.
          Don
          • Steven B.
            • June 30, 1982
            • 4000
            Don
            Don, on my '77 the sending unit wiring goes over the top then down.
            Steve
            • Donald O.
              • May 31, 1990
              • 1593
              Steve
              true, but not on a mid year and that is what the original poster was asking about.
              Don
