FINALLY, I got a copy of the service letter for steering box lube! - NCRS Discussion Boards
    • 43259
    Re: FINALLY, I got a copy of the service letter for steering box lube!
    ...having used the ...084 product for my steer gear rebuild, I can say that it is more aptly described as a "grease" rather than oil, and it is described in the Standard Parts Catalog as "Steering Gear Grease Lubricant, Hvy. Duty Corvette)". IIRC it was packaged in a soft plastic 14.5 oz. squeeze tube and somewhere I read, possibly the Chrevolet Power Manual, to inject the entire contents into the steering gear, which I did.
    Duke-----
    The 1052084 product is definitely a grease. I never referred to it as an oil; I referred to it as a lubricant, which it is.
    I have heard this sort of viscosity grease described as "140 wt". However, I do not know if that is accurate. That's why I said it was APPROXIMATELY 140 wt.
    • Gary C.
      Administrator
      • October 1, 1982
      • 17773
      link to "00" grease which was used by 50's Chevy steering box rebuilder that shows the temp and other tech info. Gary....
      tristatesynthetics.com is your first and best source for all of the information you’re looking for. From general topics to more of what you would expect to find here, tristatesynthetics.com has it all. We hope you find what you are searching for!
      NCRS Texas Chapter
      https://www.ncrstexas.org/
        • 15706
        #18
        Oils, which are definitely liquid though, perhaps, quite viscous - on the order of honey - are referred to by "weight". Greases are categorizied, among other specs, by "consistency", which is expressed by the NGLI (National Grease lubrication Institute) number.
        Most automotive grease lubrication requirements specifiy NGLI #2 consistency, which is fairly soft - like a paste.
        The higher the NGLI number the "stiffer" the grease until you get to something that is almost like a wax candle.
        I haven't looking at this for some time, but IIRC the NGLI numbers go from #1 to #6.
