Vacuum advanced correct sorce - NCRS Discussion Boards
  • James B.
    • June 21, 2009
    • 28
    Hi all this is my first post, I have a 69 L36 , (my first vett), I'm trying to find out the correct vacuum source for my vacuum advanced, on the front of the Q jet or the side?? Also, how do I find the exact production date? I believe it is Oct 68 build, C00 on trim code, 704242 VIN
    Thank You
    Jim
  • Jeffrey S.
    • May 31, 1988
    • 1890
    Re: Vacuum advanced correct sorce
    Jim:
    The vacuum source for the vacuum advance is on the front of the carb. The side port is for the AIR pump (actually the diverter valve). I also have an Oct '68 car 5854.
    Jeff
      • 15616
      Thank You
      Jim
      Jim,
      Please take another, closer, look at the letter and numbers on your trim tag following the word CHEVROLET. It helps to have a good flashlight to shine in there. I believe you will find either C08 or C10. I would appreciate knowing which you find -- and welcome to the Tech Board.
      • James B.
        • June 21, 2009
        • 28
        I used a flash light this time and the code is C09
        TY Jim
        • James B.
          • June 21, 2009
          • 28
          Hi Jeff
          Thanks for the info, my car doesnt have the air pump on it. I will need to change to the correct port.
          Tell me a little about your 69. Have you had your car judged?
          TY
          Jim
            • 15616
            Thank you Jim. October 9, 1968 was a Saturday
