In Parts Catalogs, what does SHP mean? - NCRS Discussion Boards
  • Bill I.
    • January 29, 2008
    • 554
    I see things like 67, 327 except SHP. I have a 67 L79, it that considered SHP? Thanks, Bill
  • John C.
    • January 1, 2005
    • 616
    Re: In Parts Catalogs, what does SHP mean?
    SHP = special high performance. The L79 was considered SHP engine.
    John
    • Chris E.
      • November 3, 2006
      • 1331
      John
      It's nice to be special.
      Chris Enstrom
      2011 Z06, red/red
      • Wayne M.
        • March 1, 1980
        • 6414
        SHP = special high performance. The L79 was considered SHP engine....
        This was Chevrolet's way to differentiate between parts applications in their P&A catalogs. In the front pages of these catalogs they list, for each year, what displacement and which engine identification codes would be identified in more easily understood parts-counter and car owner terms, back in the day.
        An example for 1965: There were 19 different engine stamp pad codes (a record, I believe). But you could reduce these to a combination of common English terms.
        Manual trans = HE (250hp - base engine, not mentioned)
        Manual trans and High Performance = HF (300hp, not mentioned)
        Special High Performance and Hydraulic Lifters = HT (350hp, not mentioned)
        Special High Performance = HH (365hp with solid lifters, not mentioned)
        Fuel Injection = HG (needed no further descriptive)
        In conjunction with the above, additional descriptives of: Transistor Ignitiion, C.A.C. (air cond.), Powerglide, where permissible, they could cover all combinations without resorting to engine alpha codes.
        Another example, for '67: If a big block, you could get into descriptives like: Heavy Duty, Aluminum Heads, Tri-Carb, A.I.R. (smog).
        • Warren F.
          • December 1, 1987
          • 1516
          There is a difference. HP means high performance, and SHP means special high performance. In big blocks hydraulic lifter engines were referred to as HP and solid lifter engines were SHP.
