Bent Fan Blade - NCRS Discussion Boards
Bent Fan Blade
  • Rob H.
    • April 30, 2006
    • 121
    Bent Fan Blade
    Hey there - was out driving my '69 L36 last weekend when I heard what I thought was a broken belt hitting the underside of my hood. Turns out on further inspection that one of the blades of the fan somehow got bent and was rubbing against the radiator! It is dog-eared about the last 1/3rd of the blade and is bent toward the radiator. I'm guessing some form of debris must have been kicked-up into it? Anyone had this happen to them before?
    Well now I have a weekend project on my hands. I'm going to start with the obvious symptom first and replace the fan and go from there. Any helpful tips I should know about replacing it?
    Thanks in advance for any advice and help...got to get her back on the road before Summer ends!
    Cheers,
    Rob
  • Timothy B.
    • April 30, 1983
    • 5202
    Re: Bent Fan Blade
    Rob, If it's not bent to bad try to straighten it and reuse.
    • Rick S.
      • January 1, 2003
      • 1203
      Re: Bent Fan Blade
      Tim,
      My concerns with a bent fan blade and any attempt to straighten it would be: 1) Balance 2) Fatigue. Just my .02
      Rick
      • Dick W.
        • 10483
        Re: Bent Fan Blade
        I would NOT straighten a fan blade! Like already stated, the fatigue where the blade is bent could lead to a crack, ultimately sending a blade thru the hood.
        Dick Whittington
        • Jeff G.
          • October 25, 2006
          • 187
          Re: Bent Fan Blade
          Take a close look at the water pump and fan clutch while your in there. If it's been out of balance for a while you could have more issues.
