starter issue on 66 - NCRS Discussion Boards
starter issue on 66
  • Bill S.
    • January 31, 2007
    • 396
    starter issue on 66
    i am having on going problems with my starter on my 66 427. every once in a while it will not engage. it will whirl. i put in a new one last week, these are part store replacments, i took note of the flywheel as it was stopped where the last starter would not engage. i did not see any significant wear on the teeth, but some. the new starter did the same and i decided to turn the engine by hand on the off chance it was a "flat spot" it engaged right off. i then shimmed based on the sound as instructions showed. all seemed fine, but out of the blue it started again today. i turned the engine by hand and it started fine. i brought it in the bay and it would not engage. i decided to leave it and do some research. could it be the flywheel? or is it the after market starter not having the power it needs if the flywheel is not posisioned just right? i need to solve this before carlise.
  • Bill I.
    • January 29, 2008
    • 554
    Re: starter issue on 66
    Bill, have you replaced the 'Bendix Spring" ? Bill
    • Bill S.
      • January 31, 2007
      • 396
      i installed a new starter incuding the bendix.
      • Clem Z.
        • January 1, 2006
        • 9427
        does the starter have the brace to the block on the front ? are the starter bolts the ones with the knurl ?
        • Bill S.
          • January 31, 2007
          • 396
          yes on both. the stater always seems snug when i remove them. i went about a year with a factory "365" starter after the motor rebuild then had a bad solonoid. i then decided to store the 365 starter and install a over the counter starter thinking it would be more reliable. a year and a half later with no issues i replaced the trans. after that as i had posted earlier i have been plagued with problems. i wish you could pull the inspection cover with out pulling the starter and the oil canister. i will pull the cover and put it all back and visually inspect the engagment.
          • Paul J.
            • September 9, 2008
            • 2091
            Is the starter shimmed?
            • Bill S.
              • January 31, 2007
              • 396
              yes, but maybe not correctly. it is my understanding shimming will not make the difference between engagment and nonengagment it only will effect longevity and noise, will not know until i pull the cover and reassemble and inspect. i am leaning towards the flywheel. how worn would it have to be to not engage enough to turn the engine?
                Bill -
                I think the ring gear would REALLY have to be trashed to be the cause of the problem; I've never seen one that bad. I'd suspect the Bendix before the flywheel ring gear.
                  • 6948
                  Bill, being in the auto repair bussiness these days reman. parts quality seems to really be at a low when it comes to reman. starters and alt.s my advice if you didnt have this problem before I would be looking at puttting in another starter. ive been there and done it many times.I do have good luck with ac delco remans. you should know that there a different qualitys also. with in the same brand of delco. be sure to ask.
                  • Bill S.
                    • January 31, 2007
                    • 396
                    i just got out from underneath it. looks like i have a bad fly wheel. the teeth are half what they should be in one spot.
                    • Bill S.
                      • January 31, 2007
                      • 396
                      i am going to try shimming the starter in more before condemning the ring gear.
                      • Timothy B.
                        • April 30, 1983
                        • 5192
                        Bill,
                        I think shims will move the starter away from the ring gear.
                        • Bill S.
                          • January 31, 2007
                          • 396
                          if you shim both holes. shimming the hole one on the outside, i believe, brings it closer what i am now trying to determine is how far gone can the teeth be and still work.
                          • Timothy B.
                            • April 30, 1983
                            • 5192
                            Bill,
                            Can you unhook the coil + wire, get under the car safely and have someone crank the engine and watch to see when it happens the position of the ring gear teeth in relation to the starter drive.
                            I know this sounds crazy but did you count the teeth on the bendix drive and compare them to the old starter?? Could a foreign made bendix be the problem?
                            • Bill S.
                              • January 31, 2007
                              • 396
                              i have it at rest in the problem area. what i will do is check the mesh here. i can disengage the starter and just engage the bedix gear which is what is really relevant for the starter to work.
