69 weather strip install - NCRS Discussion Boards
  • Jim M.
    • February 23, 2009
    • 233
    getting ready to install the A and B pillar weather strip. both appear to fit pretty snug into the stainless trim pieces. I'm wondering if I really need to glue these or can I get by without?
  • Michael B.
    • June 18, 2007
    • 400
    Re: 69 weather strip install
    I believe the instructions specifically say not to use any adhesive at those locations.
      • 3418
      Hi Jim,
      I'm surprised at Michael's report.
      In 71 both those WS pieces had the famous yellow goop on the backside in the SS trim piece they fit into.
      • Jim M.
        • February 23, 2009
        • 233
        thanks mike. are the instructions you refer to the "assembly manual"?
        • Brandon T.
          • October 23, 2008
          • 872
          i've wondered about this on my 68 too. i put them in without any glue
          • Michael B.
            • June 18, 2007
            • 400
            I stand corrected. After reviewing the AIM and my car the W/S is glued to the channel. The upper most piece of the A pillar is not glued to the whidshield header. The 68-72 has a hinged piece that is glued and screwed to the forward door jam area. The B pillar is also glued in.
            One other note. If you are using the 68-E69 B-pillar W/S you might need to glue the lower horizontal portion too. Mine kept catching on the door and bending up. A little spot of sealer took care of it. 2nd and 3rd versions didn't have this little horizontal piece.
              • 3418
              Hi Mike,
              Thanks so much for your second post. I was afraid I might be on very thin ice.
              I checked my originals and was pretty sure what I was seeing, so I wondered if it was 'change' by year. As 'leaky' as some cars are I'd think the weather strip installation was something St. Louis paid attention to.
              • Jim M.
                • February 23, 2009
                • 233
                thanks again mike and all who responded. guess i'll get out that "lovely to work with" 3M weatherstrip glue and put them in. jim
