Battery disconnect switch ? - NCRS Discussion Boards
  • Peter M.
    • April 8, 2007
    • 570
    Where can I purchase the side terminal battery disconnect switch that I see on most of the NCRS Top Flight cars?
  • Clark K.
    • January 12, 2009
    • 536
    Re: Battery disconnect switch ?
    In the Operations Section of Flight Judging, three items will get you 3 bonus points apiece, with all three garnering 10 bonus points. They are: (1) a NCRS decal affixed to the window (do NOT cover the date code) (2) a fire extinquisher (3) battery disconnect switch.
    Here is a link to Eckler's: http://www.ecklers.com/product.asp?p...1&dept_id=1107
    There are other companies that sell this item, also. -Clark
    • Roy V.
      • April 8, 2008
      • 308
      Peter, I ordered that very same cutoff switch from a J.C. Whitney catalog, If I remember correctly it went for about $25.00.
      1972 LT-1 Elkhart Green Coupe
      • Richard T.
        • June 23, 2008
        • 67
        Amazon has this switch for under $25.
        • Harmon C.
          • August 31, 1994
          • 3228
          Driveline ad by a member.
          Lyle
          • Willard M.
            • August 31, 1979
            • 422
            I use this blade type shut off on all of my cars except the C6. I like the ease of disconnect and I have had no failures like with the familiar green knob. There is even a discount for NCRS members for buying from the Driveline ad.
            • Peter M.
              • April 8, 2007
              • 570
              Lyle - I have been told by other members that there is an ad for these blade type disconnects in the Driveline, but I just can find it. Can you point me in the right direction?
                • 15606
                Try page 92 of the current issue. If you don't have a paper copy it is on-line above. No excuses now.
                • Willard M.
                  • August 31, 1979
                  • 422
                  847-639-1691. Order several.
                  • Peter M.
                    • April 8, 2007
                    • 570
                    Thanks guys
                    • Peter M.
                      • April 8, 2007
                      • 570
                      Has anyone heard or have first hand knowledge that these blade type disconnect switches are unsafe? Please advise.
                        • 15606
                        • John D.
                          • December 1, 1979
                          • 5507
                          I found the switch much too big for my 84. I installed it anyway but it was smack up against the inner fender. Very hard to use also. But still better than the green knob.
