1964 Powerglide Removal - NCRS Discussion Boards
  • Paul S.
    • June 30, 1982
    • 354
    I've Take Bunches Of 4 Speeds Out Of Midyears ,but I Have A Friend Who Needs To Take A Glide Out Of A '64. Will It Drop Out After You Unbolt The Convertor? (since Mid Years Don't Have A Removable Trans. Crossmember) I Didn't Know If The Tranny Will Come Out Without Jacking The Motor Up. How Bout Some Pointers. Thanks !
  • Chris W.
    • September 30, 1982
    • 49
    Re: 1964 Powerglide Removal
    It is VERY close but it will come out. I use a good transmission jack and tip the tail shaft housing up as I lower it. It is close but it will come out.
    Chris
    • Ray G.
      • May 31, 1986
      • 1189
      Hello;
      May I just add, control the torque converter. It's heavy. If it falls on you, it really hurts. Don't ask me how I know.
      Regards.
      Ray
      I hope you dance
      • John D.
        • December 1, 1979
        • 5507
        Chris
        Hi Chris, I am amazed that you are on this forum. Welcome aboard old friend. JD
        • Chris W.
          • 49
          Hi John,
          I guess this is easier then going to the shop and getting some work done. I guess I am getting old, or something. I have to give you a call some day as I need a few parts. I hope everything is well with you,
          Take care, Chris
