C-3 Trailing Arm Removal - NCRS Discussion Boards
  • David W.
    • December 27, 2007
    • 81
    Re: C-3 Trailing Arm Removal
    Chris,
    Thanks for the advice. I have been spraying them down. From all of the replies, I now have hope of getting the bolts out without needing to saw the car in half!
    When I do get them out I plan on sending them to Bairs. Do you remember their turn-around time on the work? And is the $350.00 per side cost include new spindles?
    Thanks, David
    • Gary J.
      • April 1, 1980
      • 1246
      I think you only have two choices and that is Blairs and Vansteel. Both have web sites, so you may be able to get a pretty good idea from that.
      • Christopher K.
        • September 10, 2007
        • 311
        #18
        Dave,
        My T/A's took a couple weeks, but I told them I was not in a hurry. The rebuild does not include new spindles. My arms were rusted so I ended up paying $150 x 2 more for new used arms. Then there's the original Delco backing plate, $30 x 2 to replate. This was by far the biggest expenditure so far in my restoration.
        On the brighter side, I dropped off my t/a's in person in Linesville and met Brian and Ed. They took my t/a's apart while I waited and then gave me a tour of the shop. Very good people to deal with and they did a great job.
        Chris
        Chris
        '72 Lt-1 a/c Pewter Silver coupe Mason Dixon Chapter Top Flight 2016
        '73 L82 4 spd Dark Metallic Blue coupe Chapter Top Flight 2023
        • Joe R.
          • July 31, 1976
          • 4552
          #19
          Bair's at 1 800 421-9644. They are in Linesville PA and will send you a shipping box to make the shipping easy.
          JR
          • Steven B.
            • June 30, 1982
            • 4011
            #20
            Originally posted by David White (48330)
            Thanks John. Any idea on the cost?
            David, www.bairs.com
            Steve
            1965-82 Rebuilt Rear Suspension
            Matching numbers & top quality work are important to your Corvette
            Choose Bair's to protect your investment
            We will professionally rebuild YOUR rear trailing arm to TOP QUALITY
            PARTS:
            1 Inner Bearing
            1 Outer Bearing
            1 Inner Race
            1 Outer Race
            1 Shim & Spacer
            1 Inner Seal
            1 Outer Seal
            1 Inner Dust Shield
            1 Castle Nut & Washer
            1 Handbrake Cable Guide
            1 Handbrake Adjuster
            1 Set S.S. Handbrake Springs
            1 Anchor Bolt Lock
            1 Backing Shield
            2 Handbrake Shoes
            2 Handbrake Levers
            5 Wheel Studs
            5 Rotor Rivets
            1 Front Trailing Arm Bushing Kit
            4 Trailing Arm Studs & Nuts
            $349.00
            814-683-4223
            ORDER LINE ONLY 800-421-9644
            3 YEAR GUARANTEE
            Unlimited Mileage
            LABOR
            Complete Inspection of all Parts
            Clean & Detail Parts
            Check over 30 Spot Welds on Trailing Arm
            Rebuild Trailing Arm
            Set Up Bearings to GM Specs
            Assemble Handbrake Hardware
            Check Spindle Support (each year is different)
            Recondition Spindle Support
            Recondition Spindle Flange
            Recondition Caliper Support Braket
            Rivet & Machine Rotor to Match Spindle and Remove Run Out
            Press Front T-Arm Bushing into Arm
            Pack Wheel Bearings with High Quality Grease
            Press Together & Torque to GM Specs
            Adjust Handbrake
            Free Custom Built Shipping Boxes
            MATCHING NUMBERS (DATES)
            Over -39 Years Experience, Same Location
            • Joseph K.
              • August 26, 2008
              • 407
              #21
              Find trusted experts for free. Get matched with professionals in your state for all your financial planning needs.
              He was the best price and I got a new set for a little more than a total rebuild. Geat people and helpful info.
              Joe
              • Harmon C.
                • August 31, 1994
                • 3228
                #22
                Bairs does good work and will treat you right but don't think and old rusted set of ams will get done for $349. a side. If you hane bad spindles and arms expect the cost to go up as it should. They can't make a silk purse out of a bears ear.
                Lyle
                • Jim T.
                  • March 1, 1993
                  • 5351
                  #23
                  Trailing arm rebuilding by www.bairs.com probably has the most experience in rebuilding trailing arms. I have used Bairs to return my spindles to the original condition of having the brake disc rivetted to the spindle and trued.
                  • John M.
                    • November 10, 2008
                    • 364
                    #24
                    They're definately top notch. Especially sending you shipping containers for the arms. I was pleased enough that I'm letting them restore my Front Spindles and rotors as well.
                    There's enough to worry about with restoring these cars and sometimes it's best to let the Pro's do some of it.
                    Trailing Arms is definately one example.
                    A-arm bushings is another.
