C1 Radiator - How to tell if my '57 radiator is original - NCRS Discussion Boards
  • Charles C.
    • May 31, 1978
    • 65
    What would be some telltail signs to look for to determine if my '57 radiator is original or not?
    Thanks.
    Charles
  • Steven B.
    • June 30, 1982
    • 4021
    Re: C1 Radiator - How to tell if my '57 radiator is original
    Thanks.
    Charles
    Charles, does your top tank have the metal tag on it? That will give you the date. Not all original tanks have the original rad. under them, though.
    Steve
    • Calvin M.
      • August 31, 2000
      • 117
      I faced the same problem with my 57 twenty years ago. I had it re-cored and its been fine ever since. Of course at that point original cores were available, and DeWitts, I don't believe, was.
        • May 31, 1974
        • 8411
        if u r interested in knowing if the core is original, measure the distance between adjacent fin tubes. one is 1/2", other is 9/16 between tubes. as I recall, originals are 1/2" apart but check the 56-7 judging manual to see if my memory is intact(the wife says it isn't ). regards, mike
