69 wiper override knob - NCRS Discussion Boards
  • Greg L.
    • March 1, 2006
    • 2291
    Which one do you guys think is correct for my 69, the one with the silver center or the all black one?
    The knob with the silver center came with the switch and neither are from my car. The all black knob did come with the car when I bought it 20 some years ago so right now I don't know which is correct.
  • Jeff G.
    • October 25, 2006
    • 187
    Re: 69 wiper override knob
    My original knob is black like the one on the left.
      • 15641
      My 1970 knob is all black.
      • Greg L.
        • March 1, 2006
        • 2291
        Okay thanks guys, I'll use the all black one on the left then.
        Any idea what year the knob on the right is for? I have it narrowed down to 71 or 72.
        • Dick W.
          • 10483
          All I can say is that the knob with the silver center was first repro'd some time in the middle or late '80's. The vendor swore that someone furnished him an original. I cannot say that I have ever seen one on an original car. I guess this is something that needs to be researched further and included in the new manual
          Dick Whittington
            • 11698
            Both 72s in my garage (Oct 71, June 72) have all-black knobs.
            Patrick
            • Dick W.
              • 10483
              The VP of Interiors (Reba) said she has never seen one on an original '68-'72. They were also available from GM with the silver center sometime after '72. Probably fit another product line
              Dick Whittington
                • 15641
                Might the one with the silver center be correct for the rear window defoger knob? Just asking, since I know squat about interiors.
                  • 11698
                  I've only seen black on those, and just saw one recently.
                  Patrick
                    • 15641
                    I guess I ought to look up from the engine compartment occasionally.
                      • 11698
                      Spending too much time contemplating tiny brass fittings in the middle of otherwise fine rubber vacuum hoses.
                        • 15641
                        Damn, you have a good memory. Must be your youth. I still think it is copper plated steel -- but that makes no sense either. Some day you young guys will figure it out.
                          • 11698
                          Copper would have had green corrosion. That fitting had none.
                            • 15641
                            Go to bed. It is later for you than me -- or are you an duty all night?
                            • Reba W.
                              • 938
                              Here is the text from the latest 1970-72 JG:
                              Override Controls and Odometer Reset Knob
                              Below the steering column are override vacuum controls for wipers, wiper door, and headlights. In the center is the wiper arm override switch, a plain round black plastic knob with grooved edges. Service replacements and reproductions have a stainless steel center. The other two controls are dull black or gray plastic pull switches.
                              This was the latest info we had when it was printed. I am not sure it was available when the 1968-69 JG was last done. But we are working on an update for that one.
