1966 corvair telescopic wheel will it work on a 66 coupe - NCRS Discussion Boards
  • Mark U.
    • June 7, 2009
    • 70
    what would have to be done to make it work or maybe it will not work.might be too much hassle to put into a vett,please advise.
  • Gary G.
    • July 31, 1998
    • 51
    Re: 1966 corvair telescopic wheel will it work on a 66 coupe
    If you do a search on the Corvair forum (corvaircenter.com) they make it sound like a direct cross.
    • Jim S.
      • August 31, 2001
      • 730
      No way is it a direct cross. Plan on grinding off welds. Obtaining and rewelding correct bracket. Shortening the steering shaft. I know that the upper end will be small enough to fit through the Corvette dash but shrouds and/or the escutcheon for 1967 would still be required. I know that a few have been converted, but it was only because they just couldn't find a real Vette column.
      Jim
      • Greg T.
        • January 1, 2004
        • 136
        You will need to remove the lower shaft. It is press fit and secured with a welded cross pin. There is a guy that fabricates the shaft ends but I can't remember his name. You will also need a new jacket. You can buy that and most other parts thru Long Island Corvette.
        • Greg T.
          • January 1, 2004
          • 136
          Talk to Bill Caldwell (15218), he is a member of this forum. He can fix you up with everything you need.
