C2 Front Coil Springs - NCRS Discussion Boards
  • Frank D.
    • December 1, 2005
    • 80
    Need to replace the non-original front coil springs on my 1965 Coupe with air conditioning. It is a top-flight car so I would like to use the most original/correct replacement spring. Have read all the similiar posts but would like your previous choices and valued opinions. Here is my research so far:
    Long Island Corvette $150 pair advertised as "correct repro to orginal
    specs, made in the USA"
    Paragon $100 pair "replacement style"
    Zip Products $100 pair "16 1/2" tall"
    Eckler's $75 pair "stock replacement"
    As always, thank you very much for your assistance.
    Frank ODonnell
  • Robert T.
    • May 31, 1993
    • 346
    Re: C2 Front Coil Springs
    Frank,
    I used the ones from LI and have had no issues. I have them on my 66, 427, coupe. Perfect ride height and great drivability.
    bob
    • Gerald C.
      • June 30, 1987
      • 1276
      I'm taking mine out of my 63 roadster. How do I test how good they are? Can I "test" them for strength, height, etc? I hate to go buy a pair if mine are good. The car rides fine now, but I'm taking the body off this winter.
      • Bill M.
        • April 1, 1977
        • 1386
        If the car sits right and rides right, the springs are perfect.
        • Gerald C.
          • June 30, 1987
          • 1276
          Is there a source for the correct "spring rate" for my springs? I guess I can have them tested at the local machine or engine builder shop.
            Spring rate isn't defined, but the Specifications table at the rear of Noland Adams' Vol 2 book gives you a LOT of specs to work with regarding the various front coil springs used on the various mid-year Corvette models (# of active coils, # of total coils, diameter, pitch, free height, working height, Etc.).
