Paint - NCRS Discussion Boards
Paint
  • Nicholas L.
    • November 1, 1982
    • 341
    Paint
    I have been looking for spray can of semi-gloss paint but all the stores seem to only have semi-flat. Are these interchangeable?
    • 3416
    Re: Paint
    Hi Nick,
    I think to some degree they are interchangeable.
    I find that the way the paint is sprayed (wet or dry) can have a surprising affect on the degree of glossiness from the same can. So you can suit what you're looking for.
    If you're asking about black, I believe Quanta Products (in THE DRIVELINE) has 5 degrees of gloss.
    • Glenn D.
      • May 31, 2002
      • 137
      Re: Paint
      Alan made a very good point (wet or dry) . I noticed that when I painted my valve covers.
      • David Z.
        • February 13, 2009
        • 50
        Re: Paint
        Sorry to be ignorant on this, but what is the "wet or dry" referring to ?
        thx, Dave.
        • Bill C.
          • May 31, 1989
          • 424
          Re: Paint
          Hi Nick,
          Depends on what you are painting, what are you doing? If its the old Krylon Semi flat black #1613 I can send you some if needed. Its not readilly available in consumer lines any more but I can still get it.
          Bill Caldwell
          • Gary B.
            • February 1, 1997
            • 7023
            Wet vs. dry spraying
            David,
            The degree of gloss that you can get from, say, a can of Rustoleum semi-gloss black varies greatly depending on whether you dust it on with light coats (dry) or spray a lot until it almost runs (wet). Spraying until it almost runs (it will look wet) will increase the final glossiness.
            Gary
            • David Z.
              • February 13, 2009
              • 50
              Re: Paint
              Thanks for clearing that up for me Gary.
              Best, Dave,
