1969 L46 Belt clearance - NCRS Discussion Boards
  • Kenny C.
    • March 2, 2009
    • 191
    Regards
    Kenny
    • 43248
    Re: 1969 L46 Belt clearance
    Originally posted by Kenny Chandler (50158)
    Regards
    Kenny
    Kenny-----
    The problem you describe is very common. You may be able to gain additional clearance by using a slightly different length belt. However, under almost any circumstances the clearance is going to be minimal. I believe that's why the belt guard was added.
    • Kenny C.
      • March 2, 2009
      • 191
      Joe
      Regards
      Kenny
      • John M.
        • November 10, 2008
        • 364
        If the belt is properly aligned and tightened, it should track true without movement.
          • 43248
          Joe
          Regards
          Kenny
          Kenny-----
          Yes, I'm sure there would be a judging penalty if the "non-correct" belt were to be discerned. You have to decide what's more important to you.
