Joe-Part number-1956 SR - NCRS Discussion Boards
  • John N.
    • February 1, 1975
    • 451
    Per the the RPO book the dual fan belts used on the 1956 SR production cars were 3737975. do you know the length and width of the belts? My parts man current records only show discontinued, without showing a successor number and a date.
    • 43271
    Re: Joe-Part number-1956 SR
    John-----
    GM #3737975 was not a belt, it was a belt UNIT. It consisted of 2 identical belts which were matched to be within 0.030" in length to be used on 2 belt pulley drive systems. The dimensions I have for these belts are 56" long and 3/8" wide. The 3737975 was discontinued from SERVICE in October, 1967 and replaced by GM #3887686 which was a belt UNIT with 2 matched belts which were 55-1/2" long and 3/8" wide.
    • Gary C.
      Administrator
      • October 1, 1982
      • 17916
      John and Joe, found the 3737975 in 61 P&A but wasn't in '58. Didn't search in between P&A's. 56.07 inches long, use listed for Series 5 & 6 V/8 Trucks 56-8 generators. Gary....
      NCRS Texas Chapter
      https://www.ncrstexas.org/
      • John N.
        • February 1, 1975
        • 451
        Joe- Gary
        Thanks for the information. What number would a NCRS judge expect to find on the individual belts. Guess I can throw away my new stencil for 3737975.
        • Gary C.
          Administrator
          • October 1, 1982
          • 17916
          John, no knowledge of those belts whether they were embossed with a part number or not. Will check with some Tri-5 guys to see if they have any info. Gary....
          NCRS Texas Chapter
            • 43271
            Joe- Gary
            John-----
            I cannot find what number was on each of the belts. It's possible that it was 3737975 but that would be unusual.
            Also, I doubt that a stencil would work even if the number is 3737975. Most of the "wrapped" construction belts of this era were embossed with the part number.
            • Clem Z.
              • January 1, 2006
              • 9427
              now days a lot of agricultural machine belts are a "wrapped" belt design as a lot of auto belts are the "cut" design type
