62 posi vent - NCRS Discussion Boards
62 posi vent
  • John F.
    • March 23, 2008
    • 2424
    62 posi vent
    What does the original vent look like? Anybody have pics? I bought a 3:55 posi to install. I just pulled the axles and started unbolting the current open unit and letting it drain. Looks to be a two-man job of taking the old one out unless I can jockey it around on a floor jack without dropping on my fingers. The car is on a good set of jack stands.
  • Gary C.
    Administrator
    • October 1, 1982
    • 17971
    Re: 62 posi vent
    John, what is the "vent" question? You've shown photos of the pumpkin/pig posi unit. Gary....
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Dennis A.
      • April 30, 1999
      • 1010
      Re: 62 posi vent
      John...
      If your rear axle housing has a vent cap, you are going to need instructions as to removing it and installing a posi rear vent line fitting that the vent line attaches to.
        Re: 62 posi vent
        John -
        The fitting, pipe, and installation is in the Posi option section of your Assembly Manual; it replaces the existing vent cap on top of the driver's side axle housing.
        • John N.
          • February 1, 1975
          • 451
          Re: 62 posi vent
          You can buy reproductions from vendors. You may need to tap the housing to put the brass fitting into the housing.
          Regards
          • John F.
            • March 23, 2008
            • 2424
            Re: 62 posi vent
            I'm sorry guys. My question was, what is the proper vent for the axle assembly? My car does not have a vent currently, but the hole is there. Iwill be putting in the above unit and wanted to have the correct vent. Thanks John for referring me to the AIM. I found it on page B192. Does the elbow sold by CC look correct? They show a plastic looking vent and the elbow. Is the vent line steel like the brake lines? Does it end just past the clip on the center housing? Is the elbow threaded into the axle housing? I hope I am a little more clear now. Can you still get the posi tag for the filler plug. I see CC has the metal tag that goes on one of the lugs.
            John
              Re: 62 posi vent
              Does the elbow sold by CC look correct? They show a plastic looking vent and the elbow. Is the vent line steel like the brake lines? Does it end just past the clip on the center housing? Is the elbow threaded into the axle housing? John
              Yes to all. It'll work fine.
              • Tom P.
                • April 1, 1980
                • 1828
                Re: 62 posi vent
                John
                John,
                The metal tag that you mention (which goes on one of the lugs), are you referring to the small metal disc which is attached to one of the forward facing studs on the rearend center case, which is attached with a nut?
                If so, ALLLLLLLLLLLLLL of the Corvette and early Chevy aftermarket vendors have TWO of those tags incorrectly labeled. For many years I have tried to get the vendors to change the labels on those discs, but basically they all refuse to make a change until notified by some kind of OFFICIAL documentation which shows that the two discs are incorrectly labeled. I have also brought this to the attention of NCRS with ZERO results. Either NCRS members are not knowledgeable enough of this issue, or they could really care less.
                Anyway, the two discs which are mislabeled are the ones for the 3.36 and 3.55 raitos. The disc for a 3.36 ratio SHOULD only have one hole for attachment. The disc for a 3.55 ratio SHOULD have two holes. The vendors have these two discs reversed in their catalog illustrations (and always have had).
                • John F.
                  • March 23, 2008
                  • 2424
                  Re: 62 posi vent
                  Tom, regarding the id discs: should the 3:55 be the disc with two holes of wich one hole is used to mount?
                  • Tom P.
                    • April 1, 1980
                    • 1828
                    Re: 62 posi vent
                    CORRECT!!!!!!!!!!!!!!!!!!!!!!!!
                    • John F.
                      • March 23, 2008
                      • 2424
                      Re: 62 posi vent
                      Thanks Tom!
                      John
                      • Tom P.
                        • April 1, 1980
                        • 1828
                        Re: 62 posi vent
                        Here is what SHOULD be in the Chevy/Vette vendors' catalogs. Compare this with what IS in their catalogs!
                        • Bob H.
                          • July 31, 2000
                          • 829
                          Re: 62 posi vent
                          I too don't understand why this is not corrected. I have an untouched 61 base car and could never understand how it got the so called "3:55" tag on it.
                          Only here did I discover this issue and now understand. I agree the books are wrong
                          • Gary C.
                            Administrator
                            • October 1, 1982
                            • 17971
                            Re: 62 posi vent
                            Bob, have been in Tom's corner about these errors as well. Correct tags will be shown in the revision of the 56-7 JM. Gary....
                            NCRS Texas Chapter
                            • Tom P.
                              • April 1, 1980
                              • 1828
                              Re: 62 posi vent
                              BUT THIS NEEDS TO BE CHANGED IN THE VENDORS' CATALOGS (both Chev pass cars and Vettes), because that is the source of repo tags from which owners purchase them!
